Tom's Hardware > Forum > Wireless Networking > Range & connectivity > Loosing Wireless G Signal In a Crowd
Forum Wireless Networking : Range & connectivity - Loosing Wireless G Signal In a Crowd
Mr. Stephens the track coach has a wireless-G Linksys router set up on our schools track sitting on a Table. On the other side of the track is a laptop. The wireless Connection works fine until there is a crowd between these two points there is connection interference and internet connection is lost. They are roughly 80 meters apart. What do you think is the cheapest and most effective way to fix the connection problems.
Do you think getting a Antenna and Putting it on a raised spot would help?
A wireless-G Range Extender http://www.newegg.com/Product/Prod [...] &Keywords= maybe?
Thanks
Sponsored Links
Raise the router above body level. 80 metres is a fair stretch for wireless so an extender might make sense.
Reply to fihart
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
