Tom's Hardware Forums » Graphic & Displays » Graphics Cards » Intel Motherboard/ATI Radeon Output Problem
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Intel Motherboard/ATI Radeon Output Problem
Profile: stranger
More Information
Hello, I recently was returning from college and setting my computer back up. I had everything plugged in, Turned it on and the screen was black. At first I thought the problem was with the monitor, but I tested it on my laptop and it worked flawlessly. I also tried a different monitor on my computer and the same results, nothing. I had thought it might be the ATI Radeon 9600XT AIW graphics card I have. I took it out and plugged the monitor into the Intel Motherboard to use the onboard graphics card. I get the same results. Nothing but a black screen. No chance to even see bios or anything like that. I also took the battery out of the mobo to reset the bios thinking maybe that would fix it. Yet, I have no luck. Has anyone here experienced a problem like this and if so how have they corrected it?
It is a custom built computer and I am running Ubuntu Hardy Heron as my main OS with XP as my alt. If I could get even a little output on my screen, it may help me figure out what is going on. Also, I hear no beeps indicating that there was a problem. Everything seems to be on and working, but just no output. Lights, fans, cooling system etc.
The processor is a P4 3.0. 2G Ram, 2 HDs, and 2 CD drives.
Any information about how to possibly check and find out whats wrong would help me a great deal.
Thanks,
Brian
Related Pr oduct
Profile: Faithful Poster
More Information
sounds like the card?
card did not work in both systems therefore its the card - u need a new one
http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Profile: enthusiast
More Information
Not sure its the card, especially since you tried the onboard graphics. But it could be, go buy a $20 PCI gfx card to see if that is your problem. If not, idk what to say.
Profile: journeyman
More Information
Just to verify, the machine IS passing POST, correct? (The single beep when you start up)
Pentium Dual-Core @ 3.33Ghz (333mhz x10)
2 GB Crucial DDR2 800
Gigabyte GA-P35-DS3L
Visontek HD 4850 512MB GDDR3
Profile: stranger
More Information
No sound when I boot. Thus I don't believe it passes post. I did however remove the jumper for the bios on the motherboard while the graphics card was out. Then I booted up, and there was a sequence of beeps. Which turned out: " . .   . . . . ." So, Two followed by five. I checked and the two is a parity, the five is related to the processor I think and seven is similar to five. I believe five stated about the processor being not properly put in, so I took it out, and replaced it with no luck.
Thanks, for responding so quickly.
Any help is welcome.
Brian
Profile: journeyman
More Information
Okay, have you tried to reseat all the power connections to the motherboard? (CPU, 24/20 pin, Aux)?
Profile: stranger
More Information
I just reset the power connections and I get the same results with the Blank Screen.
Profile: stranger
More Information
Does this sound like the motherboard is shot? Or could it be something else? I could just go ahead and buy a new mobo, but I gotta get an old one.
Add a reply
Google Ads
