Tom's Hardware > Forum > Homebuilt Systems > New System Build > How do the parts for this new system I plan to build sound?
Forum Homebuilt Systems : New System Build - How do the parts for this new system I plan to build sound?
How does this Newegg system sound so far? I am due for a new one after using a crappy laptop for a couple years. I hardly ever play any games, so buying a top of the line video card is a complete waste for me. My questions are whether or not 380W is enough power for this. I'm also wondering if the fan I chose will be a good choice. Any suggestions or advice would be appreciated. Thank you!
Microsoft Windows Vista Home Premium SP1 64-bit English 1pk DSP OEI DVD
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400
ZALMAN 9500A 92mm 2 Ball CPU Cooler
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK
PNY VCG96512GXPB GeForce 9600GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Antec earthwatts EA380 ATX12V v2.0 380W Power Supply
Antec Solo Black/Silver Steel ATX Mid Tower Computer Case
Seagate Barracuda 7200.11 ST3750330AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive
Pioneer 20X DVD±R DVD Burner Black IDE Model DVR-115DBK
SAMSUNG 2253BW Black 22" 2ms(GTG) DVI Widescreen LCD Monitor
Sponsored Links
Don't know about the wattage for that card, or if there is interest in overclocking. 380 should do it but I'm not sure how much headroom you'd have.
It sounds like your needs are modest. Even still, you may want to look at the 430 W range.
Reply to buzznut
- 0 +
yeah, 430w would be nice, but he does not game, and i think that the ew 380 watters are pretty good and stable. http://www.evga.com/products/moreI [...] P3-N861-AR
says they need at least 400w, or 26 amps on the 12v rail. the 380w, 430w and 500w have a combined 34 amps with both 12v rails, so the 380w should handle it...but the 430w is ont 10 bucks more if you could swing it, just peace of mind ya know?
Message edited by patater on 04-29-2008 at 04:21:24 AM
------------------------------ msi k9a platinum
x2 5400+ brisbane
patriot extreme ddr2800 cl4
too lazy to put in p500 pump :)
Reply to patater
- 0 +
2 PROBLEMS I see with this.
PSU, GFX.
I can kinda understand the graphics card, if your budget can't budge by 80 bucks more, otherwise It would be time to consider a better proformer.
The PSU is pretty low, What if you wanted to put an 9800GX2 in there? Are you going to want to replace that PSU? You've kind of forced yourself to stay with your current low power demands.
Reply to Psymonx
There are 1191 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
