Tom's Hardware Forums » Homebuilt Systems » New System Build » Power supply for 3 way SLI
Related thread(s):
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Power supply for 3 way SLI
Profile: stranger
More Information
If i would build a system with 3 way SLI, Which power supply would you recommend me, as the ones im familiar with only have enough connectors for 2 way SLI.
The graphics cards are 3 of Nvidia 9800 GTX
Related Pr oduct
Profile: Ancient Poster
More Information
Well, each 9800 use 2 pcie connectors, so that's 6 total. Aside from that, there are other parts to a computer than just the graphics cards, and those matter when power consumption is concerned. 800watts should more than cover it though.
Did you buy the 3 9800gtx yet? If not, consider those benchmarks before purchasing:
9800gtx vs 8800gts:
http://en.expreview.com/2008/04/03 [...] review/12/
9800gx2 vs hd4870:
http://forums.legitreviews.com/about15370.html
Q6600@3.6ghz, GA-EX38-DS4 X38 chipset motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB 7200rpm 32mb cache hdd, 850watt 12v rails=4x20amp powersupply
Profile: stranger
More Information
I really want to get 9800 gtx graphic cards
Monkey wants to steal peaches
Profile: Faithful Poster
More Information
Not cheap but might be the sort of thing you are after. http://www.yoyotech.co.uk/product_ [...] d8441d5448
Forums are like a herd of performing elephants with diarrhoea -- massive, difficult to
redirect, awe-inspiring, entertaining, and a source of mind-boggling amounts of excrement
when you least expect it.
Ironhide: Why are we fighting to save the humans?
Profile: nimble knuckle
More Information
NVIDIA Certified for 3-SLI and excellent reviews accross the board (@anandtech today).
http://www.scan.co.uk/Products/Pro [...] tID=782927
More Information
Nice find.
More Information
A friend just asked me to check it out for his new system so I knew the specs by heart. Saw the review today and told him to order it for his new system just a few hours ago. :sol:
Profile: enthusiast
More Information
This corair is an excellent PSU from what I've heard. Checkout this link
http://www.slizone.com/object/slizone_build_psu.html
The only other high quality ones I can see are the Tagan BZ series and maybe the coolermaster or thermaltake altough I wouldn't go for them. I am very pleased with my Tagan BZ 1300w - it looks great, is of high quality, its modular and there isn't really anything it can't handle at the moment.
DD Water Box Plus, QX9650 @ 3.9ghz, eVGA 780i, 4GB Corsair XMS2 DDR2 800(2x2gb), WD Raptor 150gb, 500gb Seagate Barracuda, BFG 8800GTX 620/2000 x 2 SLI, Tagan BZ 1300w PSU, Custom 120.2 Water Cooling
Add a reply
Google Ads
