News
The M2, Sony's new Memory Stick
Published on September 30, 2005
Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
OCZ adds two more 2 GByte gamer memory kits
Published on November 15, 2005
Just in case you are still keeping track of the memory kits for gamers that are popping up for the Christmas season, here is another one for your shopping list. Read more
Intel, Micron Sample 200 MB/s Flash Memory
Published on February 01, 2008
Intel and Micron are first to announce NAND flash memory chips using the new high-speed interface specified by the Open NAND Flash Interface (ONFI) group: The new memory promises five times the read/write performance of flash memory devices available on the market today. Read more
Latest Reviews & Articles
Value In SLI? GTX 260 Core 216 Vs. GTX 280
Published on January 05, 2009
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
Published on December 31, 2008
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
Published on December 30, 2008
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
  Tom's Hardware Forums » Motherboards & Memory » Memory » Another 4GB memory problem
Word :   Username :
Bottom
Author
 Thread : Another 4GB memory problem
Profile: newbie
More Information
I have been searching this forum and it appears many people are having problems to get 4GB of RAM to work. I have tried all of the proposed solutions of lowering the timings and multiplier but still no luck. I have 4 Patriot DDR800 sticks. I can install 3 of them and the system boots OK. However when I add a 4th the system will not POST. I have tried different combinations and am sure its not a bad stick. I have also verified its not a bad memory slot.
Here is my config.
Gigabyte 965P-DS3 v3.3 (latest bios)
4X Patriot PC2-6400
I have tried the following options.
System Memory Multiplier 800,667 and 400.
Increased the memory voltage from +1 to +4. System fails to boot at +5
Default timings 5-5-5-16-3
Any suggestions would be greatly appreciated!
Thanks
Bart
Related Product
Profile: nimble knuckle
More Information
Try running memtest on each stick to see if the memory is good.
Profile: newbie
More Information
Sorry for the noob question... Is memtest a bios utility?
Profile: member
More Information
Maybe the 4th Dimm is bad not sure but to answer the question about the Memtest.
Here you go :wahoo:
http://www.softpedia.com/get/Tweak [...] Test.shtml
BIOS has a MEM TEST that can be enabled when booting up (usually has a couple of settings fast, med, slow), but use the above and enable the BIOS Memtest to fast.
Suggestion:
put everything back to stock settings (Voltage, timings, Multiplyer, etc.). Get everything back on stock for a bit (make sure it is stable) then try adding the the 4th stick and see if it posts.
Message edited by Radio_Active on 06-26-2008 at 09:46:23 PM
E8400 @ 3.6Ghz
2x 2gigs Patriot PC8500 @1066
EVGA 780i
2x EVGA 8800GTX SLI
Google Ads
