i believe i have this mother board with the on board audio (HD audio) and there has been a problem with the sound
the problem is i need to turn up my volume a lot more than i use to...the sound has gotten a lot softer than what it use to be...now i can almost turn up my speaker all the way and it still sounds weak
i also tried to head phone and its the same way
i believe its the on board audio and not the speaker itself
what is the problem?
It has been a long time since I installed the driver for the sound
for this mother board don't i have to get the driver from the website instead of the motherboard cd because the drivers from the mother board cd wouldn't work? did u have the similar problem?
Re-install of the driver would have reset all volume levels, balance and anything else that was different to default. More than likely there was something turned down, off somewhere that was reset with the driver install
------------------------------"This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
