News
Kingston, OCZ launch new gaming memory
Published on May 24, 2006
Kingston today announced two new gaming memory models in its Hyperx series. The new modules, DDR2 1000 MHz (PC2-8000) and DDR2 1066 MHz (PC2-8500), offer 5-5-5-15-1 and run in a 2.2 volt mode. Read more
OCZ announces DDR2-800 performance memory
Published on May 02, 2005
OCZ announced the release of the PC2-6400 EB ("Enhanced Bandwidth") Platinum series as extension to its performance memory lineup. Read more
Baby Dies After VOIP 911 Call Sends Ambulance To Wrong City
Published on May 07, 2008
An 18-month old toddler in Calgary, Canada, died after it took two ambulances 40 minutes to get to him after the VOIP phone used to make the call mislead the emergency services. Read more
Mushkin's New Triple-Chan DDR3 Kits
Published on November 19, 2008
With all the buzz surrounding the Intel Core i7 debut, memory manufacturers are delivering the goods. Mushkin is now offering up its triple channel kits to the mix, with some pretty impressive timings. Read more
Latest Reviews & Articles
Value In SLI? GTX 260 Core 216 Vs. GTX 280
Published on January 05, 2009
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
Published on December 31, 2008
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
Published on December 30, 2008
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
  Tom's Hardware Forums » Motherboards & Memory » Memory » 6400 vs 8500 (Company sent me the wrong ram)
Word :   Username :
Bottom
Author
 Thread : 6400 vs 8500 (Company sent me the wrong ram)
Profile: stranger
More Information
Hi all
Ive ordered 4 x 1gb pc2 8500 ocz reaper ram but I got
2 x 1gb 8500 and
2 x 2gb 6400
What would be the best way to deal with this? Keep the ram as it will give me a total of 6gb ram or send the 2 x 2gb slower ram back and get my original order of 2 x 1gb 8500 ram?
Is there really a big difference between the speed of the ram?
I have a q6700 cpu, 9800GTX and gigabyte p35 ds3l motherboard.
Thanx alot
Related Product
Profile: Forum Fixture
More Information
No, there is no noticable difference between speed of ram in games or any real applications. But for typical usage, there is no difference between 4gb and 6gb either, since 4+ gb is more than you'll be able to use without very heavy multitasking or atypical programs.
You're okay either way. :p
Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Profile: enthusiast
More Information
That's an interesting mix up!
The difference between PC2-6400 and PC2-8500 is that the 8500 will allow you to overclock your processor more before you have to overclock the memory. I believe the Q6700 has a multiplier of 10x?
6400 = DDR2-800. With this memory, you can overclock the Q6700 up to 4.0Ghz (400mhz x 10). The 8500 = DDR2-1066 would OC the processor up to 5.3Ghz.
Now clearly you can't actually reach those overclocks, so really to answer your question I would just use the DDR2-800 (6400), as long as the "timings" are low. 4-4-4-12 is nice and low. 5-5-5-15 occurs more often though.
If you don't mind going through the return/RMA process, I'd probably return the whole bunch and buy a cheaper 2x2gb DDR2-800 pack!
Profile: addict
More Information
l
What he said.
Profile: stranger
More Information
Thanx guys, think Ill prob stick with what ive got, alot less hassle. will just open the package and insert the rest of the ram (running on 2gb only atm).
What you guys are saying is that Ill still be able to overclock my cpu to 3ghz without the memmory being a problem?
Profile: addict
More Information
smous wrote :
Hi all
2 x 1gb 8500 and
2 x 2gb 6400
Thanx alot
Performance wise, there won't be much difference between pc2-6400 CL4 and pc2-8500 CL5. However, unless you are using a 64bit OS, your system won't be able to use all 6gb of the Ram. The max would be 3.5 to 4gb.
Bux.to | .view .click .make money
Profile: addict
More Information
You are in luck. Lucky that they sent you DDR2-800 Ram.
Your Motherboard, Ga-P35-DS3L works the best with DDR2-800 Ram.
Be sure you set the voltages in BIOS to what the Manuf. specs are.
Send the 8500 back.
Profile: enthusiast
More Information
Yep, overclocking to 3Ghz shouldn't be a problem at all. In fact, all you will likely have to do is adjust the fsb from 266 to 300 w/o worrying about voltages. Your memory won't be an issue :)
EDIT: Knotknut snuck in there so I better edit for clarity: You won't likely need to make any volt changes for your processor/overclock @ 300 fsb. He's talking about the voltage for the memory sticks and what they recommend for them (1.9-2.2 usually)
Message edited by jevon on 06-27-2008 at 01:14:50 AM
Profile: addict
More Information
Overclocking GA-P35-DS3L
Sorry, I use as few words as possible. Try this link
http://www.tomshardware.com/forum/ [...] 0#t1742852
Message edited by knotknut on 06-27-2008 at 01:36:04 AM
Profile: stranger
More Information
Cool
Thanx for the quick replies. You guys helped me out alot. Gonna take all the info onboard and sleep on it tonight. Think ill send the 8500 back.
Google Ads
