Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » Thinking of upgradin my system, Thoughts?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Thinking of upgradin my system, Thoughts?
Some Things Never Change...
Profile: stranger
More Information
My System Specs Below:
Asus P5B Deluxe Mobo
Q6600 OCe'd @ 3.2Gig, on Zalman Cooler
8 Gigs Corsair XMS Ram DDR2-800
BFG 8800GTS 512MB
2 Seagate 320gig in Raid-0 7200.10
1 Seaget 320 Gig 7200.10 Back-Up
Audigy 2 Z Series Sound Card
PC Power and Cooling 750W PSU
Sony DVD Player-IDE
HP Dvd Burner-IDE
Ok, i was thinking of upggrading my harddrives to 2 seagate 500Gig 7200.11 in Raid-O and upgrading my DVD player and DVD burner to Sata Drives. What do you guys think? Worth the upgrade?
Asus P5B Deluxe | Intel Q6600 @ 3.2Gigz On Zalman 9700 Cooler| 8GB Corsair XMS2 6400 | BFG 8800 GTS 512MB | PC Power & Cooling 750w PSU| Antec 900 | Dual Seagte 320 Gig SATA II in Raid 0 and 1 Seagte 320 Gig SATA II Back-up | Dual Monitors | XP Pro 64Bi
Related Pr oduct
Do not eat the styrofoam
Profile: Forum Fixture
More Information
Nope. I don't think your PC needs any upgrades this year.
If you need more room, by all means add more hard disks. If you don't, and you just want to replace the old disks, it makes no sense to me. The speed improvements between 7200.10 and 7200.11 are too small to make it worth while.
As for the burners, if you replace them with SATA versions, all you get is narrower cables and (hopefully) a small improvement in cooling, if the wide IDE cables were impeding airflow. Again, not worth it IMO.
If you've got money and really really want to spend it, maybe get yourself a nice monitor. What have you got now?
Profile: old hand
More Information
Definately not.
Exchange Engineer - Am I working to live, or am I living to work?
More Information
OK, here's a crazy idea. Add more disks and do a different kind of RAID, something with a safer behavior than RAID 0.
Profile: stranger
More Information
I have 2 19 inch wide screen monitors that have served me well. I was thinking about getting bigger ones, but im pretty happy with what i got.
There is ALWAYS a drone.
Profile: Faithful Poster
More Information
I agree with both of aevm's posts. If you go RAID-5, you'll get to spend money on a RAID controller.
Keyboard? Rodent? UPS? Speakers? Headphones?
There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
More Information
I think the P5B Deluxe can do RAID 5 already. Is it this one here?
http://www.newegg.com/Product/Prod [...] 813131045R
The problem with the monitors is that you need to upgrade both together, to identical models. If you try to live with a 19" and a 22" side by side it stinks.
Yeah, maybe some speakers... Or some more games, one can never have enough games. :)
More Information
Mobo RAID-5 will be a lot slower than RAID-5 on a separate card, and a separate card will allow you to move the array to another PC later.
More Information
Ah, good to know.
OK, I'm out of ideas now. That PC is just too good.
Ironhide: Why are we fighting to save the humans?
Profile: nimble knuckle
More Information
The old saying "If it's not broken don't fix it!" comes to mind.
RAID-5 is a good idea but you need a hardware raid controller for it.
Add a reply
Google Ads
