Hi,
I just got a new custom built PC with the Asus Striker II NSE motherboard, which came with their little SupremeFX sound card. The card is installed on the board but I can't get it to work. The system says its not installed, and I can't seem to get any drivers working for it, either from the support CD or downloaded - I just keep getting errors (a "hardware not compatible" error when I'm trying to install drivers from their own CD for their own sound card which is installed on their own motherboard???).
Anyway, I want to ditch this card and install my own oldish but reliable Audigy SB 2 ZS http://www.komplett.ie/k/ki.aspx?sku=302657.
I'm not too technically minded so I've got a couple of questions for anyone who is familiar enough with this particular motherboard (http://www.komplett.ie/k/ki.aspx?sku=347288).
The first thing is that the interface type on my soundcard is "PCI" but the mobo seems to have slots for "PCIe". Are these compatible?
The second thing is that the supplied SupremeFX card doesn't seem to use a regular sized PCI slot and is connected to the mobo some other way. Do I need to remove this card or would it be ok to leave it there, seeing as how the system doesn't seem to know its there in the first place?
Thirdly, I'm really not familiar with BIOS options. Do I need to change anything in the BIOS if I'm not going to be using their sound card?
Fourth and finally - The Audigy card I have is a couple of years old at this stage and was built for Windows XP / 2000 etc. Will this work ok with Vista? Are there new Vista drivers I can get for it?
Thanks!
Thanks!
