OCZ said it has added the PC-4800 Platinum Elite Edition (EE) to its memory lineup. Read more
Thermaltake announced recently that three new products in its PC case, power supply and cooling system lineups have recently received Nvidia ESA (enthusiast system architecture) hardware platform certification from Nvidia. Read more
When it comes to cases and case accessories, Antec is usually at the forefront of innovation and style, and at NVISION 08, it's no different Read more
Pre CES 2007 coverage - Atlantic has a new idea how to make an iPod more useful in the outdoor world. Read more
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
Some say 2010 and even 2009 will be the year of SSDs. We think not. Read more
Tom's Hardware Forums »
Homebuilt Systems
General Homebuilt »
Best and Easiest PC Case for Elite System?
| Bottom | |
| Author |
Thread : Best and Easiest PC Case for Elite System?
Profile: stranger
More Information
I'm trying to put together an elite system, but there doesn't seem to be a consensus recommendation for the best PC cases. Here are the base components I intend to use:
Message edited by Kant on 05-04-2008 at 09:25:35 AM |
Related Product
Master of Reality
Profile: enthusiast
More Information
the Cosmos has terrible cooling wich will be a serious problem with 3 Ultras. Both the 900 and Armor are supposed to have excellent cooling and are spacious, its really just a matter of preferance from there.
Profile: addict
More Information
Of those three I would choose the Antec 900, because I dislike the looks and style of the Armor, but if you like the look then go for it.
Profile: addict
More Information
I cant help you much about your case, but about a good psu, I HIGHLY recommend this one,
--------------- Gigabyte GA-P35-DS3L*Intel E2180 OC 3.00Ghz Lapped*PowerColor ATI 3850 256MB*Patriot 2x1GB DDR2 800*Cooler Master CM690*Western Digital 250 GB*Silverstone Strider 600 Watt Modular PSU*Samsung Lightscribe Drive*CoolerMaster Geminni II Lapped Mirror Finish |
Profile: stranger
More Information
Thanks for the responses. I'll probably go with the Antec Nine Hundred. I've heard a lot of good things about the case and never anything bad, so I can't go wrong.
Profile: addict
More Information
Get a good air cooler like the Thermalright Ultra-120 Extreme for the Antec 900, don't worry about water cooling unless you really want it. As for power supply, the one linked to earlier is extreme overkill and would end up just being a waste of money, even though it is a quality power supply. I would look instead at a Corsair TX650, TX750 or PC Power and Cooling Silencer 610W or 750W. The 750W ones would be best if you think you will end up with 3x 8800Ultra, the 610/650W ones will be enough for 2x 8800Ultra. |
Profile: stranger
More Information
Profile: addict
More Information
Here is you a case with liquid cooling system built in. Since you plan to splurge for the best components then buy this case.
Profile: stranger
More Information
Profile: journeyman
More Information
Wait for the Antec 1200, it will be out shortly!
Profile: stranger
More Information
Profile: addict
More Information
If you are willing to splurge on a good liquid cooling system, then get the parts and put it together yourself, you will find that it is of better quality then the stuff built into cases. Get full-cover waterblocks for the 8800s from Danger-Den or similar, in fact, get a Danger-Den TDX CPU block also if you go water cooling. The Striker II has the built in water capabilities for the chipset, so that is taken care of. You'll need to choose a pump, reservoir, cooling solution, tubing and fillport on your own, but look at http://www.frozencpu.com for some parts for this. Pre-assembled water cooling kits tend not to work as well as doing a custom job yourself, and if you are splurging the money for the best stuff, take the time to read up on water cooling and do the best job you can with it to get the most out of your system. |
Profile: stranger
More Information
Play more, pay more!
Profile: addict
More Information
First build?
--------------- Yes, I've calibrated SpeedFan! |
Homebuilt Systems
General Homebuilt »
