~Help~ E8400 Budget Cooling?
Ok. I am stuck between these two heatsinks...
Ultra X-Wind CPU Fan Aluminum Socket
Arctic ACFZ7- PRO
I can get the Ultra X-wind for a total of 27 dollars inc. shipping
I can get the Arctic ACFZ7 for 32 dollars inc shipping.
I am planning to OC a e8400 to 3.6 ghz...
What should I buy?
If not any here, what would you recommend for a "less than $30 heatsink"
Thanks!
5 answers Last reply
More about help e8400 budget cooling
  1. For overclocking I wouldn't suggest any "less than $30 heatsink".
    Now, as long as your case will fit it:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
    For $4.00 more than the Arctic you will never regret it.
  2. +1 to that utter dominance
  3. ^+1 for the S1283.
    Arctic ACFZ7- PRO
    What should I buy?
    Thanks!
    ACF7P is $22+ @directron.
  5. im using the acf7 pro (getting xigy dark knight) and i have my e8400 @ 4ghz keeps it cool around 30c idle and 50c 100% load
Heatsinks Cooling Overclocking Product
