Archived from groups: comp.sys.palmtops (More info?)
Hello there,
I'm own a Palm m130.
Palm OS v.4.1.
Palm Desktop 4.1 (Windows 98)
While I was on holiday the battery off my palm became empty.
I tried to do an hotsync afterwards but it didn't work.
In detail:
*) I put the palm in the usb-cradle.
*) I can switch it on.
*) I press hotsync.
- Hotsync starts like normal.
- My pc askes me for the user.
- My palm additional installed palm applications are synced
- At syncing of the datbook i receve the following error message on the
pc & syncing stopps.
==== Begin of error message =====
HOTSYNC verursachte einen Fehler durch eine ungültige Seite
in Modul DATCN20.DLL bei 0177:02935118.
Register:
EAX=00000000 CS=0177 EIP=02935118 EFLGS=00010246
EBX=008557d0 SS=017f ESP=0072f448 EBP=008c0060
ECX=0072f458 DS=017f ESI=0072f46e FS=2f4f
EDX=ffffffff ES=017f EDI=00795a2c GS=0000
Bytes bei CS:EIP:
8b 48 08 6a 00 88 0e 8d 4c 24 14 e8 9c 25 00 00
Stapelwerte:
0072f4c4 029362b8 0072f484 0072f46e ffffffff 008c0060 02d4f00c 02d4f00c
00001008 00001180 ffffffff 5f4d1c58 00000000 5f403844 00000000 0072f4e0
==== End of error message ======
- On the palm i recive the message "you need to reset your handheld
computer by tapping the button below."
*) So i reset the palm
- The data sometimes seems to be synced correctly, sometimes its lost.
- But when i try to sync again the hotsync crashes again.
*) I tried to sync the palm as well on a windows XP system.
- the behaviour is a bit different but also unsatisfactory:
Hotsyncing works normal till the datebook. But syncing of the datebook
doesn't finish even after many minutes. I don't recive an error message
on the pc, and i can stop the syncing process on the pc.
Does one of you have an idea what causes this problem & how to fix it?
googeling finaly brought me help (althoug it didn't seem to help at
first tries):
A well known DATCN20.DLL - bug caused my problems.
In Palm/desktop: Tools/Options/Tools/Check & repair any corrupted
records
solved my problem.
:-) Bernd
Bernd Breitschaedel wrote:
> Hello there,
> Palm OS v.4.1.
> In detail:
> *) I press hotsync.
> Register:
> Bytes bei CS:EIP:
> Stapelwerte:
> Thank you vor every help,
> Bernd
