Archived from groups: microsoft.public.windowsxp.basics (
More info?)
mikedv wrote:
> I tried to install windows xp and i have windows me. But, went it was
> beginning to install it had a blue sreen error message that said, cannot
> install because drive C: is corrupt and cannot be repaired. My computer works
> great though. I also tried Scandisc on drive see and it didnt find any
> errors. Why is this happenning
> thank you
As the WinXP installation routine is reporting problems with a damaged
file system, you'll probably have to format the hard drive and perform a
clean installation, rather than an upgrade. And that's assuming, mind
you, that you computer's hardware components actually are capable of
supporting WinXP.
Have you made sure that your PC's hardware components are capable
of supporting WinXP? This information will be found at the PC's
manufacturer's web site, and on Microsoft's Windows Catalog:
(http://www.microsoft.com/whdc/hcl/default.mspx) Additionally, run
Microsoft WinXP Upgrade Advisor to see if you have any incompatible
hardware components or applications.
You should, before proceeding, take a few minutes to ensure that
there are WinXP device drivers available for all of the machine's
components. There may not be, if the PC was specifically designed for
Win98/Me. Also bear in mind that PCs designed for, sold and run fine
with Win9x/Me very often do not meet WinXP's much more stringent
hardware quality requirements. This is particularly true of many
models in Compaq's consumer-class Presario product line or HP's
consumer-class Pavilion product line. WinXP, like WinNT and Win2K
before it, is quite sensitive to borderline defective or substandard
hardware (particularly motherboards, RAM and hard drives) that will
still support Win9x.
HOW TO Prepare to Upgrade Win98 or WinMe
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q316639
Upgrading to Windows XP
http://aumha.org/win5/a/xpupgrad.htm
HOW TO Troubleshoot Windows XP Problems During Installation When You
Upgrade from Windows 98 or Windows Me
http://support.microsoft.com/default.aspx?scid=KB;en-us;q310064
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
