The problem is that when I use single RAM in mobo, it gets working @ 200Mhz (using CPU-Z).But when I use both the speeds gets to 166Mhz and work in Single Channel, both RAMs are however identical.
Why is this happening? I am also not satisfied with RAM speeds (READ=1812Mb/s WRITE=803Mb/s)(Using Everest). Is this the best I can get?
My Processor P4 2.53Ghz Northwood.
My mobo is ASUS P4V8X-MX (chipset VIA P4M800).
The mobo has two RAM slots and supports DDR400, although I am not sure whether its Dual Channel or not.
The RAM TWO(2x)=Kingston KVR400X64C3A/512 (512Mb PC3200)
The RAM is mobo supported. Its in QVL(Qualified Vendors List).
Thanx.
Thanx.
