Tom's Hardware > Forum > Motherboards & Memory > Memory > RAM settings/bios problem
Forum Motherboards & Memory : Memory - RAM settings/bios problem
I have an asus p5kc mobo with E6750 and 2 sticks of Corsair XMS2-6400 TWIN2X2048-6400C4 RAM (tot 2000 mb).
The RAM is supposed to run at 4-4-4-12 2,1v which it does nicely on my system but everytime i cut the power source (ie shut down computer and pull out the powercord and plug it back in and restart) the system wont POST and after restarting a second time I get the message "Overclocking failed!" and I'm forced to run the RAM timings in their "defualt" JEDEC setting (5-5-5-18, 1,8v). No matter what I do I cannot re-set the timings back to 4-4-4-12 2,1v without POST failure and then the "Overclocking failed! message (even though nothing is overclocked in my system).
Only after resetting the CMOS using the jumper switch am I able to set the RAM at 4-4-4-12 2,1v again, but only until the next "poweroff" and I will have to reset CMOS again....
Is this normal? If no what can be causing this?
Note that with poweroff I mean actually cutting the powersupply to the PSU after shutting down comp (pulling cord or using on/off- switch on back of PSU)
Sponsored Links
Well it's possible the RAM simply isn't running stably even though it's rated at 4-4-4-12. What if you try increasing the voltage on the RAM to 2.2, maybe even 2.3? If that's the case I would attempt to RMA the RAM and see if new sticks fix the issue. Good Luck, and if i think of anything else I'll be sure to post back.
Edit: Welcome to the Forums! =)
Message edited by jumpman on 07-04-2008 at 01:21:21 AM
------------------------------ Core2Duo e6600 @ 3ghz || 2GB Kingston DDR2-533 @ 667mhz || GeForce 8800GTS @ core 650mhz-memory 2.2ghz || 20" Samsung 204b LCD || 19" Viewsonic CRT || DFI Infinity 975x || 70GB Raptor || Creative Audigy 2 ZS || Creative 4.1+Kenwood 5.1=9.2 Awesomeness =)
Reply to jumpman
There are 507 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
