Tom's Hardware Forums » Homebuilt Systems » New System Build » ~$1000-1300 rig to be built.... How do my components look?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : ~$1000-1300 rig to be built.... How do my components look?
Profile: stranger
More Information
Hello fellow posters.
I have been spending a good month looking over threads/reviews/articles on this site and I finally have the money to custom build my own computer.
Everything will be puchased from Newegg,mwave, and Amazon and I would like to spend the least amount of money... basically the best bang for the buck.
Games I play: Wow, SC2, half life 2, COD4, other present/future FPS's. This computer would ideally last 3 or more years with the ability to play future games at pretty good resolutions.
Overclocking? I have never done it before, but I will definitely try it out. I heard that I can get the 6600 to 3.00+ so I would probably aim for that.
Components that look good to me so far:
Monitor: Dell 20" Ultrasharp>>>> $300
Case: Antec P182 >>>>>$150 Shipped
CPU: q6600 (quad core @2.4) >>>>$220 shipped {Alternatives: e8400, q9450}
GPU: EVGA 8800gts 512 OC >>>>$270 shipped
Mobo: GIGABYTE GA-EX38-DS4>>>> ~220 shipped {Alternatives: GIGABYTE GA-P35-DS3L ~$105 shipped}
PSU: CORSAIR 520HX>>>>>>> $112 shipped after rebate
HD: Seagate 320GB 7200rpm>>>>>$100 shipped
Memory: 4GB or 8gb @ 800 (2gb x2/4)>>>>>$70-140 {Comment: What brand? 4gb vs. 8gb?}
CPU cooler: XIGMATEK HDT-S1283 >>>>$40 shipped
DVD-drive: whatever>>>>$40 shipped
OEM: Windows Vista Home premium OEM>>>>$110 shipped
This computer is going to complement my laptop which will take care of all the daily tasks and programs. I am going to try to keep this computer for gaming only but may later use it as my main computer (in 1+ years).
Thanks and feel free to leave any suggestions/thoughts.
Message edited by buildarig on 05-07-2008 at 03:17:47 AM
Related Pr oduct
Profile: Forum Veteran
More Information
P35 is fine for q6600 and cost $100 less. For e8400 and q9450, you'll need x38/48 to overclock them to their limits. Doesn't matter if you do not overclock.
Get 4gb of ram in 2x2 sticks. 8gb won't give you performance increase, at least not at the moment. Not sure about brand.
Everything else good as is.
Q6600@3.6ghz, GA-EX38-DS4 X38 chipset motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB 7200rpm 32mb cache hdd, 850watt 12v rails=4x20amp powersupply
Profile: stranger
More Information
Where can you get the q9450? It has gotten good reviews but it isn't available anywhere :cry:
Message edited by CaliSlug on 05-07-2008 at 05:47:59 AM
Profile: nimble knuckle
More Information
I wouldn't use the DS3L for a quad. Stick to something with an 8pin CPU connector. http://www.xbitlabs.com/articles/m [...] s3l_9.html
Any p35 board with the 8pin CPU connector should be fine for a quad. The DS3L is GREAT for duals though.
Also, 4GB of RAM is more then enough. I believe there is some G.Skill DDR2 1000 on newegg for $70. http://www.newegg.com/Product/Prod [...] _-20231145
Use promo code EMCAFACAB SALE ENDS 5/8/08
The Truth About GPU Power Consumption
Home: E4600@3.6Ghz|AC7|P35|4GB|640GB|8800GT|Vista64|24" P-MVA
Work: Phenom9500@2.5Ghz|AC64|690G|3GB|500GB|8600GT|XP|2x22" TN
Profile: enthusiast
More Information
I'd change the Hard drive to a new western digital 640gb. Its around the same price but gives very good performance. Unless that is the seagate is the 7200.11 series. Those are pretty good hard drives.
Profile: stranger
More Information
Thanks for the advice dagger. I am going to go with the 6600 as it has good reviews.
TSI- which mobo in particular would you recommend? Why is the DS3L a bad card for the quad? Also, DDdr2 800 or 1000?
Sciggy - thanks. I will go with the 640 WD as many recommend it. More space too. :)
Roll on you bears!
Profile: journeyman
More Information
If you're looking for best bang for the buck i'd buy a stock GTS and overclock it yourself if you so desire. Toms has a brand new guide on how to do it if you need some tips.
Also, are you going to be using the 64 bit or 32 bit version of vista? If it's just 32, then anything above 4Gb is a complete waste, if you're using 64 you might think about going 8Gb and disabling the swap file.
I'd also like to say that the Corsair HX is an amazing PSU. I currently use the 620 in my comp and i have nothing but praise for it. Cool, quiet, stable and modular. Great Choice there.
Good Luck!
More Information
Take a look at the link I posted. Quads are power hungry, especially when overclocked! You need a board that can give it the juice it needs. I like the DFI P35 boards. Any of them should work well. (Keep in mind, I own a DS3L for my personal build but the vdroop with a quad is pretty bad, it ROCKS with a dual though)
http://www.newegg.com/Product/Prod [...] rchInDesc=
Also, that link I posted for the G.Skill is the best RAM for anything close to that price but snag it before thursday! I paid $120 for my 4GB of DDR2 800
Message quoted 1 times
Message edited by TSIMonster on 05-07-2008 at 08:14:03 AM
Reformulated with 20 percent less ahole !
More Information
my 2 cents is get a 19 inch for 169 instead of 300...there are plenty of awesom 19's for gaming at almost half the price, spend that extra 150 on yourself, or some games ! the acers at newegg look good, or samsungs at 200 bucks :) just a thought. If you wanna spend 300, go for a 22 inch acer or samsung !
X2 5400+, Biostar TA780G M2+ MATX, 2 gig mushkin, 8800gts 512 , CM 532, Kingwin 450w ATX 2.2
"Now if the 4870x2 was actually notably faster than the 280 for about the same price, then I might even take a chance on it. However, that won't be the case."
More Information
If you're not gonna overclock either, 2 sticks of 2 gig mushkin 4 gigs total is 70 bucks at egg, it runs great stock and 1.8 volts to 2 volts.
More Information
@ joethe one..8800gts has terrible overclocking due to memory chips near their limit 8800gt is the sweet spot for bang for the buck, that said the 8800gts runs cooler with the double height setup ...plus it's just cooler ! Bang for the buckwise goes to 8800gt right now around 175 at Newegg !
Profile: stranger
More Information
TSI- thanks so much! Okay so, I read in your previous link that the reviewers liked the Blood Iron version. It looks good and a decent price. Will I miss out on anything by choosing the cheapest (blood iron card)? I don't plan on SLI /crossfire and will probably just upgrade my GPU in a year or so with what ever the next best Nvidia is at the time. Yeah, I think G.skill is about the cheapest.
Joe - Yeah... I guess I should save myself $30-40 and overclock it myself. I have never overclocked before so if all goes wrong I can just fall back on a slightly OC'd card worse case scenario, but its silly to pay so much for something that won't take me too much time. Also, I am going 64bit so I have been toying with the idea of getting 8 gigs of ram, but it seems like I won't use it now... or will I?
As for memory... do I want ddr2 800 still with the DFI bloodiron + q6600?
RoyalCrown - I'll have to look into the monitors more...I am wary of just about every company now. Samsung for example uses different panels on the same monitor and one is significantly better than the other. I think I won't want anything bigger than 19-20" because games seem to run better at these resolutions and it seems like the next logical step is to get a 24", which is out of my price range/ too extravagant at this time.
Profile: stranger
More Information
Ah... after reading comparison charts, people seem to say to just get the e8400/x38 combo if your into gaming because quad cores will probably not be utilized for a good while. I just wish there was one answer to the cpu :(
More Information
http://www.newegg.com/Product/Prod [...] 6824009091
It might be a good option...and their new 24 did get awesome gaming reviews for 300, but you say you wanna go 20 max. I'd savw the 100 bucks and give up the inch and use it to buy crysis or something cool to run on your rig. :)
More Information
Actually the mainstream right now and best size vs price are the 22 inch monitors 1680 x 1050 something, according to the charts you don't get a big FPS drop going to that step from a 19. :)
Roll on you bears!
Profile: journeyman
More Information
The thing about quad vs dual core is that today, not many games show much improvement with a quad core. Since that is the case, the popular thing to do today is buy a high clocked dual a la e8400. However, you said that you want this thing to last for 3 years, and by then who knows if games will use 4 cores or not. It really all comes down to the prices of these 2 chips and whether you think the extra 2 cores will be worth it. You really can't go wrong with either right now as both are great chips.
As for the 8Gb vs. 4Gb debate, I believe toms has another article on that, you may want to check it out:
http://www.tomshardware.com/review [...] ,1775.html
Profile: stranger
More Information
I'll look into the 22" Royal, thanks. I think 24" is too big for me :).
Joe- Thanks for that. I think I'll put in the extra 4gigs since it costs what? $70? It will be good for the future anyways.
Overclocked with a CPU fan (like the one mentioned), which CPU runs cooler, q6600 or the e8400? If I were to go with the e8400, is the x38 board the best buy? Thanks for the tips!
More Information
If it's any consolation, buildarig, I am torn between a good 19 at 175 or so and a good 22 for 220, so I am in the same boat :)
More Information
http://www.anandtech.com/displays/ [...] i=2944&p=7
there is an article, kinda old though, but worth a look. Personally, I hear the dells rock too..I just wanted to put up a link so you could get an idea what's out there around $250 that's good.
Sniper
Profile: Forum Fixture
More Information
@OP:
If you are planing on getting RAM natively higher than DDR2 800 be aware that there might be compatibility issues. Many users reports and my personal testing has shown that there is a very good chance you will run in to issues with RAM higher than DDR2 800, such as DDR2 1066. I recommend you get quality DDR2 800 RAM and run them at 1:1 ratio or overclock the RAM. This issue dose not apply to DDR2 800 RAM that has been overclocked.
Message edited by Shadow7037 93 on 05-07-2008 at 01:17:00 PM
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
More Information
n°1806631
05-07-2008 at 05:41:21 PM
Hide
