Tom's Hardware Forums » CPU & Components » Sound Cards » Moving sound card to a different PCI slot
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Moving sound card to a different PCI slot
Nvidia Fanboy
Profile: journeyman
More Information
Hi all,
I have major newb question here, but I want to ask anyway. If I move a soundcard from one pci slot to a different do I need to remove the device first? I assume yes, but I figured Iwould ask first.
Thanks!
Related Pr oduct
Profile: newbie
More Information
No, I don't think you need to uninstall any drivers. Simply turn off your PC, do the swap, and when you boot again, Windows will reinstall the card automatically.
Thermaltake Tsunami | Toughpower 700W || Gigabyte M59SLI-S5 || AMD Athlon X2 5000+ @ 3GHz
4GB Corsair XMS2 800 4-4-4-12 || eVGA Geforce 8800GT
Western Digital Raptor 150GB|Caviar 250GB SE16
Logitech G15|G5 v2|Z-680 || Zalman 9500 || Samsung 226BW ||
BAM!
Profile: Faithful Poster
More Information
Dont need to, power off , reseat card in the other slot turn back on now worries
"The MB is 31 C and the CPU is 109 C. I think it's the CPU overheating."
Profile: addict
More Information
the answer is no, but if you do run into some problems, reinstall the driver.
Message edited by godless on 06-10-2008 at 05:43:13 AM
Profile: journeyman
More Information
wasnt there some old motherboards that was picky about that? irq address and ports or something?
nickc07 wrote :
I dont follow any rules I just throw everything in the case.
Nvidia Fanboy
Profile: journeyman
More Information
Thank you all for the responses. These forums are the best!
Profile: addict
More Information
I was just thinking the same thing... but that was quite some time ago, cant really remember...
Add a reply
Google Ads
