SSD - The Performance Upgrade of the Future
Ok so need a bit of help in choosing a SSD There is the OCZ Vertex using the Indilinx controller - seems fast with a wiper program and good firmwear Corsair P128 - seems even faster but no trim tool Anyone know anything about the Corsair Extreme Series X128 Any more to consider? Any thoughts or tips appreciated
Have you also considered Intel's new X-25M 128GB? 60% cheaper than the older version!
+1 to what r_manic said. I'd consider TRIM support essential, particularly if you expect to be using Windows 7 at some point.
Intel X25-M (34nm) SSDSA2MH080G2 80GB $225 Intel X25-M (34nm) SSDSA2MH160G2 160GB $440 Since Intel just came out with these last week, they should start showing up in about a month. Also OCZ will be lowering their prices in the coming weeks.
definately +1 r_manic. bad time to buy a ssd. wait until intels new 34nm arrive.
