Radiator Help
Forum Overclocking : Cooler and Heatsinks - Radiator Help
Hey i'm planing on using a DD Black Ice GT Stealth 240 in my cooling loop the only problem that i'm having is that the place that i want to put the radiator is a tight fit leaving only 1-4mm of clearance with fans attached. Now will this effect the cooling power of the radiator or is this still enough space for it to function properly?
Sponsored Links
You will limit the amount of airflow that the fans will be pushing due to the minimal space. Where are you putting this that there is such little space?
------------------------------ The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Reply to rubix_1011
i have a ultra full tower case and the only place i could find to put a 240 rad was the space i have right above the power supply i'm tryin to make the case clean with as few wires and what not in the open here a pic of my case from ultra.
http://ultraproducts.com/product_d [...] ductID=411
i was thinking of putting just a 120 rad where the rear 120 is but i'm not sure if that is powerful enough to cool my core 2 quad q9650 and a radeaon 4870
Reply to db140
You are going to need at least the surface area of 3x120mm rad...preferably more. Typical rule of thumb is 1.5x120mm surface area for each major component in a cooling loop...2x120mm surface area if they are overclocked. Of course, this is somewhat dependent upon radiator and fans used...but, like I said...general rule of thumb.
A single 120 rad won't cool that CPU and GPU sufficiently. A 220 rad really won't, either, at least to the point that makes watercooling necessary...you would be better off getting aftermarket air coolers for both if you want to use a single 220 rad.
Reply to rubix_1011
ok well the GPU i'm getting comes with a very decent air cooler on it so if i'm just cooling my CPU and chipset then would a 3x120 do the job?
and also thx for your help this is my first WC rig so i dont know to much about some of it.
Message edited by db140 on 02-09-2009 at 09:39:07 PM
Reply to db140
Yeah, that would work fine...and to be honest, you probably don't need to cool the NB. You could get by (if you didn't OC) if you had the CPU and GPU on a 320 rad, but you still need to get into the cost of a GPU block and some ram sinks.
Reply to rubix_1011
well my Asus Rampage Extreme comes with NB block so it cant hurt to go ahead and put it in the loop but as for a GPU block do you have any suggestions because i'v been looking and cant descide on a good one... same with the ram sinks
My GPU is the Asus EAH4870 DK/HTDI/1GD5
Message edited by db140 on 02-09-2009 at 10:19:51 PM
Reply to db140
Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Radiator Help
There are 1314 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
