Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound distiortion issues
Forum CPU & Components : Sound Cards - Sound distiortion issues
This issue has been driving me crazy, sound starts to distort when the PC has been in use for some time. This will make music and videos distort. It doesn't matter what player I use music and video will skip. If I start a youtube video the video will have distorted sound as it downloads and will only stop after the whole video is downloaded. When I listen to music and I go to a new web page the music will crack and pop. It fixes itself when I reboot but always comes back at random times.
I have updated all drivers and I'm still having the same issues.
My PC is a custom build from me:
Windows Vista Ultimate
MSI Neo2 (P35) Motherboard using onboard sound and onboard LAN
E2160 OC @ 3.0ghz (runs cool not a heat issue)
2GB A-Data DDR2 667 RAM (Passes Memtest not a RAM issue)
x800 GTO 256 Video Card (This old thing has been getting warm with light gaming.)
SATA HDD & SATA DVD (I'm not using any IDE)
Is this a hardware problem, integrated soundcard or LAN?
Sponsored Links
Have you checked the MSI site for a firmware update, maybe theres a known problem. MSI is a bizarre company, I had an old 694D pro board that ran rock solid and never game me a single problem even oc'd to the max. So I bought a Geforce 4 TI4800 MSI GPU and what a bitch that was, the video settings never ran stable and it would fragment the screen when hot. See if you can borrow a sound card so you can check that its not your on board sound.
Reply to Vertigon
- 0 +
Try a new sound card driver, if that doesn't help buy a sound card - not Creative labs because theirs tend to hog the bus and that could be part of why you get the crackling already.
As for the other videos, distorted sound can have more than one cause, try updating your video and audio codecs. Try to isolate which video files corrupt by playing local copies instead of through your browser and find a commonality of audio & video codec that doesn't work right.
It shouldn't be a Lan issue, if the data doesn't come down the pipes fast enough the audio should drop, stop, not get garbled or crack and pop.
Reply to I
Thanks Vertigon and I for your input.
I tried new drivers once again but same results. The reason I thought it could be a LAN issue is because with I use high bandwidth I get the distortion (Downloads or Utorrent) when I'm enjoying music.
I will try a cheapo Encore sound card from newegg. I use 10+ year old Yamaha 2.0 speakers so I don't need anything fancy.
I will post back here if that doesn't solve the problem.
Reply to spoo
I installed a new sound card ENCORE ENM232-6VIA but it is still acting up. The sound is more of a skip/distortion and happens when the CPU is +70%.
I uninstalled and then reinstalled all codecs also like suggested above. I can't figure this out, help this is driving me nuts.
Reply to spoo
There are 818 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
