New System Build
Add a reply
 Word :   Username :
Bottom
Author
 Thread : New System Build
Profile: stranger
More Information
This is my new build the total is aobut 2000
       Processor
1     AMD Phenom 9850 BLACK EDITION 2.5GHz Socket AM2+ 125W Quad-Core Processor Model HD985ZXAGHBOX - Retail
    Speakers
1 Logitech Z-5500 505 Watts 5.1 Speaker
  Hard Drive
2 Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM SATA 1.5Gb/s Hard Drive
2 Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
  MotherBorad
1 ASUS M3A32-MVP Deluxe/WiFi AM2+/AM2 AMD 790FX ATX AMD Motherboard
          Case
1 Thermaltake SwordM VD5000BNA Black/ Silver Aluminum Extrusion ATX Full Tower Computer Case
              CD-Drive
1 ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T OEM
        Power Supply
1 ABS Tagan BZ Series BZ800 ATX12V / EPS12V 800W Patent Piperock Modular Power Supply
          Head Set
1 TRITTON TRI-AI712 4 x 3.5mm Connector Circumaural AX 51 - Gaming Headset
              Mouse and keyborad
1 Logitech G9 Black 5 Buttons Tilt Wheel USB Wired Laser Gaming Mouse
1 Logitech G15 2-Tone USB Wired Standard Gaming Keyboard
        Ram
2    CORSAIR 2GB (2 x 1GB) 240-Pin DDR2 1066 (PC2 8500) Dual Channel Kit Memory
 Video Card
2 MSI RX3870-T2D512E OC Radeon HD 3870 512MB 256-bit GDDR4 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video CardMicrosoft Windows Vista Ultimate SP1 64-bit English 1pk DSP OEI DVD
       OS
1       Microsoft Windows Vista Ultimate SP1 64-bit English 1pk DSP OEI DVD
Related Pr oduct
Profile: Forum Veteran
More Information
Looks like you're aiming to overclock the Phenom to 3ghz-ish. :D
I don't think you need any advice. You have done your homework. If I may, what are the uses of the pc?
e8400@4ghz | Coolit Freezone | LP UT ICFX3200-T2R/G | HR-05-SLI | Ballistix PC2-6400 4x1GB | HD 4850 | HD753LJ | GSA-H62N | EGA1000EWL | RC-690-KKN1-GP | Vista 32 | W/V=A
Get out of here...and take your fail with you.
Profile: member
You might wait for the 48xx series to come out. It should be here by the end of the month; I think 480 SPUs will be worth waiting for :)
You might consider a Corsair PSU (750 TX or 620 HX) rather than the ABS Tagan.
And I prefer a Razer gaming mouse (just because.).
Intel Core 2 Quad Q6600 G0 @ 2.68 GHz/1.12v (Stock cooling p'wns!) - Gigabyte GA-G31M-S2L - 4 GB A-Data DDR2 800 @ 850 MHz/5-5-5-15 - GeForce 8800 GS (EVGA 384-P3-N851-AR) @ 700/1745/2056 - ASUS Vento mini tower - Seagate 250 GB 7200.10 hdd - Razer KRAIT
Profile: stranger
More Information
The only use for this PC is Gaming Vid card will be crossed fire
Message edited by konaguy on 05-08-2008 at 07:21:41 PM
Profile: stranger
More Information
The motherboard will be:
Add a reply
Google Ads
