Depends on if you need an operating system or peripheras (keyboard, mouse, speakers, monitor) But this would get you a really good setup with plenty of hard drive space. I would definitely go with the QX9650, its just a better all around processor than the Q9300 (higher clock speed, unlocked mulit, more cache)
Here is the setup:
ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T - Retail Item #: N82E16827135156
Return Policy: Standard Return Policy $34.99
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail Item #: N82E16811129021
Return Policy: Standard Return Policy $119.99
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM Item #: N82E16822136218
Return Policy: Limited 30-Day Return Policy $114.99
EVGA 512-P3-N845-AR GeForce 8800GTS (G92) KO 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Robert Wilensky: We've all heard that a million monkeys banging on a million typewriters will eventually reproduce the entire works of Shakespeare. Now, thanks to the Internet, we know this is not true.
u want the qx9650. period. easy over clock to 4 ghz with a relatively small votage bump. low to mid 1.4...somethings volts depending on the chip. considering its stock 1.3v its impressive. even if u don't overclock its a solid chip (especially consdering the lack of cost). otherwise a q9300 will do 3ghz overclock on stock voltage and 1600fsb though be it with half the cache of its big brother. its a solid chip and if u were paying for it i would say get it instead....similar performance (w/ overclock to stock clocked qx9650). enjoy your new rig.
I work at the Hudson Mass intel site (F17) and just picked my free QX9650 up today and am glad I found this list. Thanks Guys. It shows you put some thought into this. Now it will join my Free 965 and 650 chips from the past 2 years as my next gamer computer. We get a new free chip every year. Come join us I think there are over 1000 job openings in the US.
