Tom's Hardware Forums » Homebuilt Systems » New System Build » Noob system builder, need opinions on build!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Noob system builder, need opinions on build!
Profile: stranger
More Information
Well this is my first system build and I want some suggestions from some seasoned vets.  The components that I am thinking of putting in it are:
CPU: Intel Yorkfield Q9450 2.66GHz processor
GPU: EVGA 8800GT 512mb in SLI (need suggestions on GPU the most)
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 1066 (PC2 8500)
MOBO: EVGA 780i
PSU: mushkin 650W ATX12V Power Supply
HDD: Western Digital Caviar 500gb 7200rpm
DVD burner: Samsung
DVD drive: Lite-On
Case: XCLIO Windtunnel
Need Suggestions
Related Pr oduct
Profile: newbie
More Information
well you gave us little information..What is your budget? etc...
i put together a build for myself and seems to possible fit you..
https://secure.newegg.com/NewVersio [...] shList.asp
any suggestions on the build i put together please reply at my thread "Ultimate Gaming PC"
Profile: member
More Information
Well your wish list was only temp so is not avaliable any more townshipla
Profile: member
More Information
Profile: member
More Information
First of all I wouldn't spend so much money on a new mobo especially since there is a new socket coming out for intel. 1066 ram in most cases is just overclocked 800 so if its cheaper thats something to concider. Hardrive go with this one instead Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
GPU my personal favorite is EVGA 512-P3-N845-AR GeForce 8800GTS (G92).
PSU I would rather go with CORSAIR CMPSU-620HX 620W ATX12V v2.2 Since you want SLI (not big fan of SLI) you might need little bit extra juice. But it should do fine.
Profile: stranger
More Information
well I was looking to spend around 1500 dollars and adding all of the costs together it would come out around that much. The RAM was 150 bucks so i dont know if that is a good price or not. And I am unsure of SLI also because all I have seen are mixed views of it.  What would be the best GPU for about 300-375 dollars? and If not the 780i mobo what would you guys suggest for the best performance? Any more info that you need just ask?
Add a reply
Google Ads
