Ok so i was trying to format my new seagate 1tb external hd over to fat32 using swissknife. I think it worked but the drive was coming up as having 434 mb of space instead of 1tb liek it should so i wanted to undo the partiton.
The problem is i have no idea how. The someone suggested a low level format but that seemed to do nothing.
The hard drive is not showing up on comp management or my comp. I dled seagate tools and ran all the dst tests and passed them all but it wont let me run any advanced test, specifically the one that would return the drive to factory settings.
Does anyone have any idea of how to get this drive back to the way it was when i bought it. Or even just so it shows up on my comp and disk management.
If you can see the drive in Disk Management, you have the tools you need. On the right side of Disk Management there are two scrolling windows; the lower one shows you the devices installed, whether they are all ready for use or not. It should show your 1 TB drive as a unit with one Partition plus a bunch of Unallocated Space. RIGHT-click on the active Partition you have already and choose to Delete it. If there are any other Partitions on the same drive (NOT ON YOUR BOOT DRIVE!), Delete them also, until the entire drive is Unallocated. Might be wise at this point to reboot.
"Low-Level Format" is not what you want; in fact, that term really is for a procedure done when the HDD is first made, and difficult for end users to do. To get a new HDD ready to use there are two steps, often covered as one procedure in a utility package, but Windows disk Manager does them separately. The first is the create one or more Partitions - each of these will be treated as a completely separate drive with its own letter name. A HDD MUST have one Primary Partition, and MAY have additional Partitions if the Primary does not use all of the drive's space. Any space not allocated to a Partition is Unallocated. A Partition (primary or not) may be bootable or may not be - your choice. A bootable Partition is flagged in the disk's MBR so it can be found and it will have some essential files installed on it for basic booting. You most certainly can create one (Primary) Partition on a drive that uses ALL of the space on the disk.
After the Partition(s) is defined, you must Format it, and this is where you specify what File System the Partition uses. Most large drive users today will choose NTFS for several reasons. There are two limits imposed by the older FAT32 system, but some users (like you) need to use that system for particular reasons. The two most significant limits of FAT32 are a limit on the maximum size of each file, and a limit on the maximum size of the disk (Partition) you can use. The latter limit can be changed, and Swissknife is one utility that can do this. The FAT32 system reserves a fixed space at the beginning of the disk for its File Allocation Table where it keeps track of which Allocation Units are used and how they link to the rest of their files. Now an Allocation Unit consists of a specified number of disk Sectors, and a Sector is always 512 bytes. Microsoft had certain numbers of Sectors per Allocation Unit they used for Formatting FAT32 disks, and this created the limit on maximum disk size. However, third party utilities like Swissknife can use larger numbers of Sectors per Allocation Unit to allow keeping proper records for a very large drive. The trade-off is that ALL files will have space allocate to them in large chunks, leading to a little more wasted space when this is done. Today, the waste is usually not a big deal because the disk is huge, anyway!
So if you want to create a single large Partition on your new 1 TB drive (after deleting all the old ones) you can. And from what I see, Swissknife may well offer to combine in one operation the creation of the Primary Partition AND the required Format operation. You have to use Swissknife to Format that Partition using the FAT32 File system, and you'll need to find where to make it use up all that space. It is done by setting the number of Sectors in one Allocation Unit (may be labeled something like Allocation Unit Size), but that detail could be hidden from you. I don't know Swissknife's user interface - maybe it just asks you how big this drive is, and figures out for you how to set up the FAT32 system. When the two jobs are done you reboot and Windows My Computer should see it ready to use.
If you can see the drive in Disk Management, you have the tools you need. On the right side of Disk Management there are two scrolling windows; the lower one shows you the devices installed, whether they are all ready for use or not. It should show your 1 TB drive as a unit with one Partition plus a bunch of Unallocated Space. RIGHT-click on the active Partition you have already and choose to Delete it. If there are any other Partitions, Delete them also, until the entire drive is Unallocated. Might be wise at this point to reboot.
"Low-Level Format" is not what you want; in fact, that term really is for a procedure done when the HDD is first made, and difficult for end users to do. To get a new HDD ready to use there are two steps, often covered as one procedure in a utility package, but windows disk Manager does them separately. The first is the create one or more Partitions - each of these will be treated as a completely separate drive with its own letter name. A HDD MUST have one Primary Partition, and MAY have additional Partitions if the Primary does not use all of the drive's space. Any space not allocated to a Partition is Unallocated. A Partition (primary or not) may be bootable or may not be - your choice. A bootable Partition is flagged in the disk's MBR so it can be found and it will have some essential files installed on it for basic booting. You most certainly can create one (Primary) {artition on a drive that uses ALL of the space on the disk.
After the Partition(s) is defined, you must Format it, and this is where you specify what File System the Partition uses. Most large drive users today will choose NTFS for several reasons. Thee are two limits imposed by the older FAT32 system, but some users (like you) need to use that system for particular reasons. The two most significant limits of FAT32 are a limit on the maximum size of each file, and a limit on the maximum size of the disk (Partition) you can use. The latter limit can be changed, and Swissknife is one utility that can do this. The FAT32 system reserves a fixed space at the beginning of the disk for its File Allocation Table where it keeps track of which Allocation Units are used and how they link to the rest of their files. Now an Allocation Unit consists of a specified number of disk Sectors, and a Sector is always 512 bytes. Microsoft had certain numbers of Sectors per Allocation Unit they used for Formatting FAT32 disks, and this created the limit on maximum disk size. However, third party utilities like Swissknife can use larger numbers of Sectors per Allocation Unit to allow keeping proper records for a very large drive. The trade-off is that ALL files will have space allocate to them in large chunks, leading to a little more wasted space when this is done. Today, the waste is usually not a big deal because the disk is huge, anyway!
So if you want to create a single large Partition on your new 1 TB drive (after dleting all the old ones) you can. And from what I see, Swissknife may well offer to combine in one opereation the cretion of the Primary Partition AND the required Format operation. Then you have to use Swissknife to Format that Partition using the FAT32 File system, and you'll need to find where to make it use up all that space. It is done by setting the number of Sectors in one Allocation Unit (may be labeled something like Allocation Unit Size), but that detail could be hidden from you. I don't know Swissknife's user interface - maybe it just asks you how big this drive is, and figures out for you how to set up the FAT32 system. When the two jobs are done you reboot and Windows My Computer should see it ready to use.
Thank you for the reply. It doesn't actually show up in disk management, My computer or BIOS and the only confirmation i have that it even works is the sound i get when i plug it in via the usb cable and the fact that seagate tools recognises it.
Actually it does show up on comp MANagement. It shows up as Disc 5 basic with 931 gbs of unallocated space. It shows up on the bottom list rather than to the right though.
OMG thank you so much. I followed your advise and i think its working. I created a new simple volume after deleting the partition and now its formatting it.
Oops! Just re-read your post and it says you can NOT see the new 1 TB drive in Windows, not even in Disk Management. Now I'm confused. You started out by saying you think it worked to format it under FAT32, but it only showed 434 MB, which is a really odd number. Where did you get that information if you cannot find it anywhere within Windows?
has free downloadable instructions and DiskWizard software for installing a new Seagate hard drive. I assume that this is a data-only drive, not your boot drive, but maybe I'm wrong. Low on that web page click on the "Learn More about DiskWizard" link to download the Seagate DiskWizard User's Guide as a .pdf file. It details all the things you can do if you download and install the DiskWizard software. In Chapter 11, "Adding a new hard disk", it details how to use the software to help you add a data disk to your system that already has a boot disk running. In Appendix A that follows, under the FAT32 heading, it specifically says that the maximum disk size it can Format for you under FAT32 is 2 TB, so this free utility package from your disk manufacturer can do all the disk preparation tasks you need. You just need to download the DiskWizard package and install it on your existing hard drive, and download the User's Guide to refer to as you use it.
HMMM! As I'm reviewing this for errors, I see you may already have things going well. So you may not need this piece of advice. However, I have found Seagate's DiskWizard really useful, so I still suggest you get it and install it for future use, even if you don't need it now.
Message edited by Paperdoc on 07-30-2009 at 09:54:51 PM
