I have overclocked my intel E4600 core 2 duo from 2.4ghz to 3.2ghz using 12x multiplier and 1066fsb plus mem 533mhz. the question i have is that i'm trying to set the fsb to 1333 and mem to 667mhz but i need to set the multiplier to 9.5 to do so but i can't seem to set it to 9.5x unless i'm missing something. if you have any info on how to set the multiplier to 9.5x it would be helpful. tried using the decimal point but that doesn't work. cheers.
pc specs as follows
win vista 32-bit
dell xps 630i
nforce630i chipset
4gb ram
geforce 9800gtx+
500gb hdd
750 watt psu
atx mobo
pc specs as follows
win vista 32-bit
dell xps 630i
nforce630i chipset
4gb ram
geforce 9800gtx+
500gb hdd
750 watt psu
atx mobo
