Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Problems Gigabyte GA-7N400 Pro2 v2.0 & Samsung HD103UJ
Forum Motherboards & Memory : Gigabyte - Problems Gigabyte GA-7N400 Pro2 v2.0 & Samsung HD103UJ
Hi There,
If somebody can help I'll appreciate it.
I have a "Gigabyte GA-7N400 Pro2 v2.0" with a "Silicon Image SiI 3512 SATALink Controller" included.
I have two IDE HDs and a SATA HD (Seagate ST332062). I tried to add a new SATA HD (Samsung HD103UJ) and the systems stops when the SATA controller detects the Samsung. It recognizes it (show the name) but stops when should show the size of the disc. I changed cables, unplugged the Seagate, cross check everything and nothing works.
I sent the disc to the shop and they tried it and works fine. I upgraded the BIOS of the system form version H to K, one version after antoher, and check if recognizes the disc and it's impossible.
Somebody can have an explanation?
Thanks.
Aturdido.
Sponsored Links
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
