Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Power Supply Question: Corsair vs PC Power
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Power Supply Question: Corsair vs PC Power
Profile: newbie
More Information
Building an SLI gaming rig:
Which power supply is quieter and which one is more reliable?
Corsair TX Series TX650W
or
PC Power & Cooling (S61EPS) Silencer 610W SLI-Ready
Related Pr oduct
Profile: member
More Information
i have used both and i like the PC&power ones better. they are more simple and a little louder but they are very dependable and give you more power than they are rated for. Because they are so efficent. They have gave me a lot of good service. Will never use anything but these.
Corsair Tech Support
Profile: addict
More Information
The PC P&C Silencer series is built by Seasonic which is the same company that builds our TX-650 to our specifications. With 2 quality units this close in specifications, I'd suggest you go with brand loyalty or possibly price as the deciding factor.
Official Corsair Tech Support. If You Need Help, Just Ask.
Profile: old hand
More Information
Go with the PC Power and Cooling, they are slightly more stable, about the same price, and are all individually tested before you receive them to ensure no DOAs and cut down on the limited possibility of a faulty PSU in general. Also, it looks sexy in the crossfire edition red!
Blasphemy is the spice of life.
Profile: enthusiast
More Information
More power is better for SLI for the price/performance i'd go with this corsair
http://www.newegg.com/Product/Prod [...] 6817139006
while it's on sale its a awersome value for a well rated product.
Profile: old hand
More Information
The Pc Power and Cooling is the same price after rebate...
http://www.newegg.com/Product/Prod [...] 6817341011
Profile: addict
More Information
LOL...I tried to find a db rating on this PSU at the PC P&C website. But, all I can find is some page trying to explain why a faster spinning 80mm fan is more quiet than a slower spinning 120mm ???
http://www.corsairmemory.com/products/tx.aspx
http://www.corsairmemory.com/_imag [...] _noise.jpg
Add a reply
Google Ads
