I don't like the raidmax cases. I've used them and they are build rather cheap. Antec 900 is a good deal.
Go for a Q6600 or other quad core. Stay away from duo core. Quads are cheap enough today, and will soon be utilized as new software takes advantage all all cores.
The Motherboard is nice. Abit are my preference. Consider the X38 board but it's more expensive.
Change your PSU. It's the most important part of the build. Maybe an Antec modular. It has a 5 year warranty and great quality.
The 19" monitor is rather small. You might want to consider a 22" which is in the same price range. The Acer is cheap and nice as well. Most 22" LCDs are similar as they use the same panel so they are the same quality.
Your DVD Burner should be SATA. Consider the Pioneer although your NEC is very good.
As for a video card check Toms Hardware VGA Buyer's Guide. It'll tell you the best card for your price range. Hard to argue with that.
If you need a hard drive go for a Seagate Barracuda in the size you require. WD Raptor if you want blazing speed and Seagate for quality with a 5 year warranty.
As for the build it's pretty simple but not if you've never done it before. Here's a basic guide.
- Open and strip case.
- Install Power supply
- Open motherboard and place on anti static bag on box. Install RAM
- Scrape factory paste pad off heatsink using razor blade and clean with a little alcohol. Don't scratch the heatsink.
- Spread some good paste such as Arctic Silver using a razor blade. Just a thin coat on the CPU die. Insert CPU in board.
- Install Heat Sink and fan
- put mounting posts in case to match motherboard layout. Insert rear shield in case that was supplied with motherboard.
- Grab motherboard by the heat sink and insert in case careful not to scratch the board on the mounting posts as you slide the board back into the shield.
- screw it in using screws which heads are smaller then the silver grounding ring around the screw holes.
- Insert CD-ROM and Hard Drive
- attach all cables
- plug it in and cross your fingers
- if it works configure the BIOS and install windows.
- unplug and tidy up cables.
If it doesn't work remove battery and reset BIOS. If still no go remove board and install on motherboard box with static bag. plug everything in and power up for troubleshooting. Do not power up board on static bag as it will short your board. The static bag is electrically conductive. Use the bag only for assembly the board...not for powering it up when troubleshooting.
Takes about 30 minutes to build if all goes well and posts on the first try.
Message edited by gondo on 05-09-2008 at 03:40:52 AM
You have 2 power supplies listed. Keep the corsair from your choices. The money saved can upgrade your monitor to an Acer 22". I'd switch the WD to a Seagate hard drive. And probably a 500GB or 750GB since it's like $15 more.
The case is your choice but there are some nice onse out there. Antec 900. Silverstone makes a beautiful case. I like their HTPC cases with remote.
Your DVD is IDE. Consider a more modern SATA model.
You'll save compared to DELL or HP. You'll also have a way faster/better computer. Better quality. And better warranty. RAM = lifetime. Monitor = 3 years. Hard drive from seagate is 5 years. Antec Power Supply = 5 years. Abit has the best warranty service in the market and it's 3 years. Video card should be 3 years. That sure beats 1 year on an HP.
i dont understand gondo - the corsair is more expensive than the other one. and ill switch to antec 900 since a lot of ppl have been telling me that =D
and ill try getting a SATA model.
as for the 19", i think thats big enough, unless there are issues with resolution or something....
Ive have a XFX it works fine, thats just rocky voicing his/her personal opinion. Also keep the corsair, its the much better buy, you want reliability, if your going to save money, save it in the processor area, or the case area, the psu is the lifeblood of your system, a crappy power supply will do in your entire system if you do something wrong.
Seriously. Between Corsair VX and the XCLIO PSU. If you want to have this computer for say 2-3 yars at least Corsair is the way to go. If you want to save some change go with XCLIO (I would rather drink tap water and eat dry bread for 1 year to save the difference if I had to).
EVGA/XFX makes no difference (by reputation). Go with what's cheaper.
ECS is a different animal (they have a bad reputation).
DVDRW : I listed the NEC AD-7191S (SATA drive) in my first post under ODD (stands for optical disk drive).
HDD : Larger usually is better. For best value and performance go with WD6400AAKS. With Seagate make sure it's a 7200.11 series drive.
First builds tend to go okey. Mind the instructions and don't force anything. Gentle and smart beats caveman tactics 100% in first build statistics.
Good luck.
Save yourself on the office program dude. I work for a school district, we just put Open Office on about 29-30 new Dells. It's free, free updates, does what you want it to do. Save your money. I've got MS Office XP at home don't even use it b/c I like Open office. Also, they are supposed to release a new version later this year of Open Office, I believe anyway, according to what that said, it's gonna support all the new Microsoft Office File types. So save a little green. If you like.
ok so here is the new configuration. Im getting the corsair psu, how do i tell if it will support my system? and will the system stay cool? (i wont overclock since i dont know how and dont know what it is)
Latency is used to describle the speed of the ram and SLI stands for Scalable Link Interface, which basically is two or more SLI enabled Nvidia cards on one motherboard. SLI can only be used on motherboards with nForce chipsets for example 750i or 780i or even 790i. The ATI equivalent of SLI is Crossfire which is basically the same thing, but can only be used on Intel chipsets.
Message edited by Maroc on 05-09-2008 at 11:37:51 PM
