Tom's Hardware Forums » Motherboards & Memory » Asus » striker II formula please help
Add a reply
 Word :   Username :
Bottom
Author
 Thread : striker II formula please help
Profile: newbie
More Information
okay guys got a problem it will not start sometimes for no reason!!! when i get it started it plays flawlessly crysis cod4 and kanes wrath for hours! Just some times when i go to turn it on it send powers to lights and fans for about a split second then cuts off. i have checked every connector and tried moved connectors around and it starts up sometimes. i have tried cutting power from the surge protector completely unplugging the pc it doesnt work! seems when i mess with the cords or move different connectors around it works. strange tho it worked fine with no issues for 2 days now im haveing problems again. any help would be greatful! I have reseated the sound card,ram,graphics card and all fans. i have pulled the power from the power supply and still wont turn on. should i cmos or just rma it???
here are my specs please help!
striker 2 formula using their sound and fans
gtx 280
dominator ddr2 1066 8 gigs ram
gigabite 1200 watt power supply
2 300 gb seagate hard drives raid 1
vista ultimate-32 bit
thermaletake liquid cooled
3 120 mm fans
3 led lights
sagitta2 mid tower by raidmax
also last night checked all the connectors finally got it back on. gamed for hours then when i turned the pc off i just wanted to check to see if it would power back on NOPE! its like 3 am so im like f it and go to bed! this morning i push power and bam its on. so i turn it off and try to turn it back on NOPE! so here i am again messing with the cords unplug everything includingharddrives try to see if i can get it doesnt come on then suddenly i power it on and it kicks on so i test it i try it like 3 times so i start installing everything go to turn it on and bam same thing power for a split second then doesnt cut on. so i turn the power supply off comeback 20 mine later hit the power button its on????????????? wtf is up with this $hizzzit is this the mobo or do i have elec prob somewhere????? please any info would be great!!!!
Related Pr oduct
Profile: Forum Veteran
More Information
Well, you have powered it on and off with enough different combinations of RAM, HDs, surge protector, etc. I would suggest breaking the system down to the basics and trying to power off and on. Unplug everything except the CPU/HSF, 1 DIMM RAM and videocard. If the systems fails to power off and on with the basics, or is powering on randomly like you described, I would suspect the motherboard. I would RMA the MB at that point and not spend another minute trying to troubleshoot it and make it work.
Message edited by badge on 07-07-2008 at 07:39:36 AM
Profile: stranger
More Information
Mine does the same thing: the main power connector on the mobo seems to have a loose contact. If the cable shifts to the "wrong" position, the power cuts out. Just jiggle it when it acts up, and it will behave itself.
hope this helps,
t-man
My rig:
http://i21.photobucket.com/albums/b271/letzdoit96/Specs070508-1.jpg
Profile: newbie
More Information
hey thanx for the responces after pulling everything out of the case and powering on the mobo alone i finally figured it out! it was my power supply. i grabed my 500 and powered on the board 100 times with no problems! then i took the 1200 gigabit odin witch btw was brand new and was powering on an older mother board without any issues. im thinking maybe the mother board is bad and keeps tripping like it cant handle the wattage. so anyway i buy a 1200w coolmax so far my pc has done about 20 boots with everything hooked up no problems. i called asus and they were saying that the ps was not compatible??????? strange but it worked! seems funny a cheaper ps works lol!
More Information
Places red x next to Gigadud 1200watter. Good work and glad you got it going.
Profile: newbie
More Information
http://i158.photobucket.com/albums/t90/jltromba/bench.jpg
well guys this is what i got on my bench.
Add a reply
Google Ads
