Tom's Hardware > Forum > Storage > DVD/CD Writers > [Problem] CD/DVD Dual boot Problem
Forum Storage : DVD/CD Writers - [Problem] CD/DVD Dual boot Problem
I have two Samsung|SH-S222A 22X. When only drive is plugged in at a time, it works. However, when both are plugged in simultaneously, neither works. How do i fix my problem?
Sponsored Links
Clarification: when either is plugged in by itself, or only one of them? You may want to try swapping cables and ports.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
Sorry, If only one of the drives is plugged in, then it works. So i can plug in one and it works. Then i unplug that and with the same wire, plug in the other drive. That one works. I can do the same with the other wire i have. So i know the problem is not with the wires. However, when both are plugged in at the same time, the computer does not read either drive as being plugged in.
Reply to cdselects7
Those are PATA drives, right? They won't both work at once if they're on the same cable and the jumpers on both of them are set to MASTER or the jumpers on both are set to SLAVE.
Reply to sminlal
Sorry I am mentally challenged, thanks for the help.
Message edited by cdselects7 on 08-05-2009 at 04:23:42 AM
Reply to cdselects7
There are 438 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
