i am trying to do a format on my pc to try to get it back to factory settings but the problems is when, i try to wipe the hard drive all i get is a personal recovery and it brings it all back to the point in which the wife did a personal recovey, i have tried a few times to do a format but it takes more memory and brings it all back ,i was wondering if a super recovery would do it but there are no discs with the pc its, all build in so am kinda scared to do it ,its just i want rid of this partition so that i can at anytime bring it back to factory settings am really needing some advice so any would be great
spec
iqon pentuim d cpu 2,80ghz 2,79ghz,100 gb of ram
media edition version 2002
service pack 3
16 hours ago - 3 days left to answer.
i have tried afew people and all thet say is put wxp discs in and to a format i would if i had the discs but its all buld in my pc
should i use the super recovery on my pc and will my wxp be build back in the system but i dont know and i hope you do so help please help
service pack 3
A Windows Media Edition OS system disk is needed for a recovery install. What you tried was System Restore. Without it, your iqon pentuim d cpu 2,80ghz 2,79ghz,100 gb of ram is about as useless as this guy's arm.
