Tom's Hardware > Forum > CPU & Components > Other Components > help choosing heatsink... want to OC
Forum CPU & Components : Other Components - help choosing heatsink... want to OC
Hi people !
I need some help to choose a decent heatsink for my cpu since i'm planning to overclock. i have an intel E2180 cpu @ 2GHz and hopefully i want to OC to 3.2GHz. i have a ECS mobo and don't know if it is frendly to OCing (haven't tested yet, i'll have it home in about two weeks). :non: I know it's not a good motherboard brand but it was not me who chose it.
don't want to spend more than $45-50. helping with links will be great, thanks !!!
PS: :cry: Germany sucked today against Croatia in Euro 2008
Sponsored Links
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
+1 for the Xigmatek. Just installed it in my board and got my e6400 to 3.0ghz right now. I'm sure it can go higher. I get a max temp of 53degrees celsius and the arctic silver hasn't even broken in yet.
If you have room in your case and can buy it, go for it. It is about 160mm tall, so it's quite big.
Reply to rabidbunny
- 0 +
i know the board may be the worst i could get. i hope i'll change it soon
Reply to ichundu
- 0 +
OCZ Vendetta II
http://www.amazon.com/OCZ-OCZTVEND [...] 946&sr=8-1
It's based off of Xigmatek's design (which I think the TRUE 120 was also) that everybody loves so much and performs just as good and sometimes a tad better than both from the reviews that I've read. The good thing is it's only $37.95 at Amazon and eligible for free shipping through Amazon Prime. Buy.com and Newegg are both about $50 and Newegg doesn't even have it in stock.
EDIT: Well I might be a tad misleading in that it was tested against a Xigmatek cooler. I know it did beat a TRUE 120 in a review or two that I read but now I don't think they tested it against any Xigmateks. But it is based off of Xigmatek's design.
Message edited by arson94 on 06-12-2008 at 09:33:52 PM
Reply to arson94
This is the number that you want to beat.
Thermal Resistance: 0.17°C/Watt
Anything higher is a waste of your money.
If this number is not given, move along.
Oh by the way this is from the Arctic Cooling Freezer 7 Pro, $32 retail.
Reply to bobbknight
- 0 +
:o sorry for the igorance, because i'm new to overclocking, but what do you mean i have to beat it? is this a parameter associated with the heatsink or what?
Reply to ichundu
http://benchmarkreviews.com/index. [...] 6&Itemid=1 This link has a comparative review of the 3 heatsinks.
Thermal resistance is a measure of heat conductivity. However, it is a theoretical figure, and doesn't always translate into real world performance, as it is only one factor that goes into cooler efficiency.
See this link for specific details on thermal conductivity. http://en.wikipedia.org/wiki/Thermal_conductivity
http://en.wikipedia.org/wiki/Therm [...] nd_systems
Message edited by rgsaunders on 06-12-2008 at 10:22:41 PM
------------------------------ Never under estimate peoples capacity for stupidity, and you won't be disappointed.
Reply to rgsaunders
+1
------------------------------ ASUS P5K-E|Q6600 G0 (@ 3.3)|4GB D.C. OCZ PLT. DDR2 800|ASUS HD3870 512MB XF
X-Fi XG Fatal1ty|2x160GB WD Sata II|2x250GB WD Sata II|Pioneer 16x DL DVD Drive|XIGMATEK 750W
20.1" LG WS LCD 1680X1050|19" Sharp LCD 1280X1024|VIsta Ultimate
Reply to MCMONOPOLY
i would either go with a Xigmatek or the TRUE. honestly, i don't think you can go wrong with either.
------------------------------ http://valid.canardpc.com/cache/banner/590311.png
Reply to aznguy0028
- 0 +
Bookmarked, cheers.
Reply to Dan515
There are 467 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
