Tom's Hardware > Forum > Storage > Hard Disks > Help!!!!! problem with my external harddisk..serious!
Forum Storage : Hard Disks - Help!!!!! problem with my external harddisk..serious!
HI
I'm having serious problem with my external harddisk Maxtor Basic Portable 320GB. If i connect to the pc...the drive shown but i cannot access the drive...if i access the drive it hanged for about 5 6 seconds and this msg is shown "H:\ is not accessible. The file or directory is corrupted and unreadable".
so i have run chkdsk /f/r from command prompt ....for chkdsk /f it did show lots of errors and being repaired but still cannot acccess...for chkdsk /r it shows no bad sector and says all fine.
Please help....i have so many important data inside. I'm out of idea for what to do next.
Thank you for in advance !!!!!!!!!!!!!!!!!
P.S Sorry for my bad English
Sponsored Links
You can try running Test Drive on the disk I guess. How important is your data? There comes a time when you have to rely on a pro and his or her accompanying equipment.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
Can you remove the drive from the case and connect directly to your PC using sata? probably wont help but worth a shot
Reply to donpacific2k
There are 1161 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
