Hi, folks, this is going to be my new computer. I need to build a storage server here and store plenty of data, but I have not decided (I am a newbie at this) which computer case/full tower and power supply are the best for me.
I also need to know if will be necessary to buy a new FAN or dedicated cooler for something. My old P4 uses a Leardership Gamer II Blueye, but only 2 Hard Drives and a single DVD+RW recorder.
The new computer will have:
- Q9450 CPU Retail/Box with heatsink/FAN;
- Motherboard Abit IP35 Pro;
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
- 2 x1 GB RAM Corsair DDR-2 800 Mhz latency 4-4-4-1-2;
- Blackmagic Intensity Pro (capture card) - already have;
- 8800 GTS 512 MB (G92 - EVGA) video card;
- PROMISE SATA300 TX4 PCI SATA II Controller Card - OEM - up to 4 HDDs SATA II:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816102062
And finally:
- 10 Hard Disk-Drives Samsung 750 GB HD753LJ
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152100
The Abit motherboard can have 6 SATA drives plus 4 on the Promise controller. Since the Promise controller uses a PCI-slot, 18 HDDs can be used.
I don't know what's the best computer case for me, capable of storing at least 10 HDDs. Perhaps one with 10 Internal 3.5 bays? Where should I put aditional drives? All cases are the same thing?
And the power supply to mantain all I said before.
And finally:
