Help!! Very strange OC problem
Here is the summary of my
MoBo: Gigabyte p35-ds3p rev 1.1
CPU: E6750
Cooling: ARCTIC COOLING Freezer 7 Pro
RAM: 4*1GB Crucial Ballistix
OS: Vista home premium SP1
I did the OC 1 and half year ago, setting the FSB at 400 to get E6750@3.2GHz, memory setting is 4-4-4-12@1.9v 800MHz. with the bios version F8
10 days ago, I found that both in windows and cpuz, it shows the cpu and memory ran back to 333MHz. However, it still show correct setting in the bios. I updated the bios to the newest F11 or even F12b version. The problem continues. Whatever you set in bios, it runs at 333MHz*8 and memory runs at 333mHz too
I do not know what is going on here. any help is appreciated.
xuz113
4 answers Last reply
More about help strange problem
  1. Could you post screen shots of your BIOS settings and of the CPU-Z and Coretemp screens?
  2. Here is all the informations.
    There are totally five photos
    BIOS:
    http://cid-059531f797ead78a.skydrive.live.com/self.aspx/ga-P35-ds3p%20E6750/IMG%7C_0748.jpg
    http://cid-059531f797ead78a.skydrive.live.com/self.aspx/ga-P35-ds3p%20E6750/IMG%7C_0749.jpg
    CPUZ:
    http://cid-059531f797ead78a.skydrive.live.com/self.aspx/ga-P35-ds3p%20E6750/CPUZ-CPU.jpg
    http://cid-059531f797ead78a.skydrive.live.com/self.aspx/ga-P35-ds3p%20E6750/CPUZ-Memory.jpg
    CoreTemp
    http://cid-059531f797ead78a.skydrive.live.com/self.aspx/ga-P35-ds3p%20E6750/Coretemp.jpg
    Thanks for help.
    xuz113
  3. What are your Ram specs?? or model #?
  4. Well, with your screen shots, it appears you have DDR2-800 4-4-4-12 Ram (that should be 2.0v) as per Crucial's web site.
    Bump up your Ram voltage to +.02, lower your FSB strap to 2.0 (1:1) so it runs at 800 Mhz, and up your vcore a couple of notches. You should be good to go.
BIOS Cooling Overclocking
