Water cooling
Forum Overclocking : Cooler and Heatsinks - Water cooling
what is a reliable well priced water cooling system for the i7?
Sponsored Links
are you askin for a preassembled system?
Reply to db140
Sorry for not specifying... Either pre-assembled or pieced together. just trying to sift through the data bull to get an excellent water cooling system for my new i7 rig. Seeing if anyone has goos info into this situation before I make a purchase.
Reply to Anonymous
mind givin some specs as to what your wanting to cool like vga, NorthBridge, Hard drives, and what not
Reply to db140
I am looking into cooling my cpu
Reply to Anonymous
build: i7 920
EVGA X58
Mushkin 6g
Vista 64
Full tower Thermaltake Xaser XI
Velociraptor 10000 rpm
1000W Corsair psu
xfx 260 gpu
Reply to Anonymous
ok that's simple enough... From what i have read around the
Swiftech Apogeeā„¢ GTZ Universal CPU Waterblock with the lga 1366 adapter would be a good Cpu water block for you...
http://www.frozencpu.com/products/ [...] tml?tl=g30
as for pump and radiator that depends on what size hose you want to use... if your just cooling ur cpu i think 3/8 will be fine for you and a 240 radiator i think will work
check out these for the pump and radiator
http://www.frozencpu.com/cat/l3/g3 [...] Page1.html
now i like swiftech product but that's for you to chose... and also you need to decide if your wanting to do a closed loop or one with a reservoir.
Message edited by db140 on 02-15-2009 at 05:08:26 AM
Reply to db140
@OP Please read:
+1 for a custom loop. Don't bother with kit's most kits are cr@p.
Conumdrum wrote :
My standard noob cut n paste:
I'll steer you to some more technical links, please spend a few days (DAYS) reading posts, searching, learning. Don't forget to look for your case with WC. Google your case and the word watercool or some combination of that. WC stuff is larger than you think, I know from experience. WC setups done right are awesome and almost silent.
Great place, not wayyy over the top with uber WC guys.
http://www.ocforums.com/index.php
Uber place, owned by one of the worlds winning OC guys in the world. Not a place to post or ask questions by noobs, but an awesome place to learn.
http://www.xtremesystems.org/forums/
Another good place to learn
http://www.overclock.net/water-cooling/
Great places to buy WC stuff
http://www.dangerden.com/index.php [...] e&Itemid=1
http://www.petrastechshop.com/
http://www.jab-tech.com/
Hope it helps, see ya in a few days, get edumacated!
Checkout:
http://www.xtremesystems.org/forum [...] p?t=202394
Read the leak testing guide very well.
Message edited by Shadow703793 on 02-15-2009 at 05:05:13 PM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Yep, thats a good link Shadow. The filter he used really isn't needed anymore with more modern stuff, otherwise, very solid and not full of wrong stuff.
Here is another build help link, one I wrote for someone else somewhere else.
http://forums.extremeoverclocking. [...] p?t=312743
Reply to Conumdrum
^Correct. The filter is no longer needed when you have Kill Coils :).
Correction. The filter is needed with old rad designs and oddities from the old days. Not an issue in todays loops with proper prep.
A Ians Killcoils (sold at Petras) is a replacement for a biocide. It's a coil of pure flat silver wire, silver is a great biocide, as is a copper compound in a liquid solution, like PT/PHN Nuke.
Please Shadow, expound a bit on your posts, you are really misleading in your reply this time. No time to post what really helps folks? Wait till next time.
Shadow, your a major help in the WC issue here, so don't take it wrong.
Message quoted 1 times
Message edited by Conumdrum on 02-17-2009 at 05:38:52 AM
Reply to Conumdrum
By the time I get here to post, you guys have scraped up all the good stuff. :|
------------------------------ The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Reply to rubix_1011
For $450 I can build an awesome more effective CPU/GPU loop than the one you listed Psycho. It seems to work okay except in really high wattage situations with a overclocked i7, then it just fails.
And thats not from review sites, thats from real users.
Reply to Conumdrum
Oh, lol, yeah I was sick over the week end, hence some of the buggy posts (this isn't the only one for that day; there were a few and were fixed). I stand corrected. ;)
Message edited by Shadow703793 on 02-17-2009 at 06:57:42 PM
Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Water cooling
There are 1155 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
