Tom's Hardware Forums » Homebuilt Systems » New System Build » $2k budget looking for advice
Add a reply
 Word :   Username :
Bottom
Author
 Thread : $2k budget looking for advice
Profile: stranger
More Information
I am about to build a new system, budget of about $2,000. I could go a bit higher if warranted. I would classify my knowledge level as "just enough to get myself in trouble" - a friend is going to actually build it for me.
I'd love some advice/criticism/suggestions from the pros here.
Antec P190 Case/Power Supply
EVGA 780i ATX MB
Intel E8500 Core 2 Duo, 3.16 M
EVGA 8800 GTS G92 (or 2, for SLI?)
Barracuda 720.11 HDs
Zalman 9700 NT CPU fan
4 Gigs Mushkin DDR2
Philips SPD6104BD LightScribe DVD Burner
Many thanks!
Related Pr oduct
Profile: addict
More Information
at your budget, get 8 gigs
Profile: nimble knuckle
More Information
SLI is really more hassel than it's worth
780i is a bad choice, if you want the ability to go SLI get the 790i.
Around the end of the month ATI should be releasing their new video cards and from the reports I've seen they should be quite good.  If I were you I would be looking at a X38/X48 board due to their better overclockability and stable performance.
I just bought the E8400 and the Rampage Formula and it's a great combo, something you might want to consider.
http://www.anandtech.com/mb/showdoc.aspx?i=3208
http://www.newegg.com/Product/Prod [...] 6813131284
Or if you really want to spend some money you can get the soon to be released Rampage Extreme which is the same board with support for DDR3.
Message edited by ausch30 on 05-11-2008 at 07:15:29 AM
Quote
"Wit is educated insolence."
-Aristotle
Add a reply
Google Ads
