I just received a Dell Precision 7500 with 3 hard drives (SAS 450GB 15k) and a DELL PERC 6i RAID controller. My priority is speed. I was wondering about two options:
- RAID 0 with all 3 discs
- 1 disk for the OS (XP) and 2 disks in RAID 0 (for data processing)
I also thought about a RAID 5, to get some data redundancy but read that write speed would decrease significantly, so I guess I'll just backup often on external hard drives.
RAID0, though i would recommend Vista/Win7 if you go this route, because you'll get more performance out of the array by avoiding a misalignment issue with Windows XP partitions, affecting the IOps performance of striping RAID.
Whether seperating your OS disk from the other stuff increases performance relies on your situation. I wouln't do a RAID5 in your case; thats aimed at large arrays where you don't want to waste 50% of your capacity to mirroring.
------------------------------...man will occasionally stumble over the truth, but usually manages to pick himself up, walk over or around it, and carry on.
Reply to sub mesa
I will not be able to get Vista or Win7 anytime soon, so could you please explain a bit more on the "misalignment issue"?
OK. So running the OS on a separate disk (not in the RAID 0 volume) will improve the performance of the RAID 0....
Do all three in a raid 0 I have I 5 disk raid 0 sooo fast if your operating system is on the raid it will be allot faster too. Just be sure to back up often I just had 1 of my 5 drives go flaky on me. It does suck when I switched out the bad drive I had to reload... No big deal I like to reload every 6 months to a year anyway but still not fun when it's not in the plans.
