I have a case - Kingwin Mutant X and i want to connect the front audio/mic connections to my motherboard which is a XFX 630i. I need some help because i heard if you fail it can damage the motherboard.
Up above is a picture of my motherboardmanual diagram to plug in the audio connectors. the ones on the case are named differently so its a bit confusing.
These are the wires I have in my case:
MIC IN
MIC BIAS
Return L
Return R
GND
SpkrOUT L
SpkrOUT R
So my question is which ones would go where? Ill appreciate anyones and everyones help.
