Tom's Hardware > Forum > Home Theatre > HDTV > DVR Problem
DVR Problem
Forum Home Theatre : HDTV - DVR Problem
Archived from groups: alt.tv.tech.hdtv (More info?)
I have a Pioneer HDTV which works great via my HDTV cable box. But
today I decided to "upgrade" to a SA 8300 HD DVR. Without changing my
cables or anything else, I plugged the new box in. My colors became
"solarized." Thinking that I had a defective box, I exchanged it.
Same problem. I don't know what to do. I'm using my component
inputs. Any suggestions? Thanks.
Sponsored Links
I had the same problrm with my DVD player.
Make sure the TV and the DVR are setup for component
inputs (not S-VID) and maybe progressive scan.
Reply to Anonymous
Did that. Cable guy couldn't fix it. So it went back.
On Fri, 19 Aug 2005 15:09:27 GMT, "dancwalker@earthlink.net"
Reply to Anonymous
.... also, I've found that the green and blue cables can be easily mixed if
you are trying to match colors with less than optimal lighting back there
"Sleep is a poor substitute for coffee."
- Anon
"Scribner" <walter3ca@yahoo.com> wrote in message
news:bvtcg19u8mshc3l878qdl8ipq3e9pu34c4@4ax.com...
Reply to Anonymous
There are 1233 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
