Tom's Hardware Forums » Homebuilt Systems » New System Build » Power supply advice needed...
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Power supply advice needed...
Profile: stranger
More Information
I posted this under the power supply/case forum, but thought that I would repost it here for those of you that may not frequent that forum as I would like your input as well.
Going to be building a pc soon. either q6600 or e8400 OC'ed. 8800GTS card.
Right now I have this power supply:
 CORSAIR CMPSU-550VX 550W
http://www.newegg.com/product/prod [...] 6817139004
which is is $85 after MIR + another $10 for shipping = $95
but I was looking and noticed this one:
 COOLER MASTER Real Power Pro RS-650-ACAA-A1 650W
http://www.newegg.com/product/prod [...] 6817171023
which is is $100 after MIR with free shipping.
So, for like $5 more can go from the 550W to the 650W power supply. I probably don't need more than the 550W, but for just $5 more wondering if I should just go ahead and get the 650W.
Related Pr oduct
Ironhide: Why are we fighting to save the humans?
Profile: nimble knuckle
More Information
I think you can get the Corsair for ~$70 from
http://www.buy.com/prod/Corsair-VX [...] 52646.html
Cooler Master makes great cases ... buy their PSUs don't share that reputation. 550W is good for a one graphics card system.
Unless you plan on doing SLI but 650W might be a bit slim for that too.
Message edited by Andrius on 05-11-2008 at 10:49:00 PM
Profile: Ancient Poster
More Information
Judging by specs, the Cooler Master psu is stronger. 12v rail ratings at 3x19amps vs 1x41 amps, plus higher 12v and overall wattage.
Here's what I use, for comparasion:
http://www.newegg.com/Product/Prod [...] 6817101029
850 watts, 12v rails at 4x20amps.
Be sure to read the newegg buyer feedback reviews. Ignore the good reviews, just read the ones rated at 1 or 2. You want to know if it's just noobs whinning or if there's actually something wrong with it.
Q6600@3.6ghz, GA-EX38-DS4 X38 chipset motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB 7200rpm 32mb cache hdd, 850watt 12v rails=4x20amp powersupply
Profile: stranger
More Information
Thanks, guys.
Think I will prob go with the $70 550W from buy.com. free shipping too. I might would look at the 650 harder if I was going to SLI or something because of the multiple rails. But, I don't plan to SLI.
Profile: old hand
^...For dual GPU SLI 550W is quite sufficient...so don't worry, 550VX is a great buy.
Intel E6750 * Gigabyte GA-P35-DS3L * Galaxy 8800GT 512mb 620MHz* Corsair VX450 * 2GB Transcend 667* 2x120GB Seagate SATA * Altec Lansing ATP3*
Profile: Forum Veteran
More Information
The published specs don't tell you the quality of the components or design.
Cooler Master PSUs are junk. Apparently the 1000W is better, but IMO it is a good idea to steer clear of all Cooler Master PSUs.
More Information
I'd rather not have 2x 8800GTS( 2 x 150W max) and an OCed quadcore(120W+) on a 550W PSU. Maybe I'm silly but it'd be running close to the limit and that's a bad idea even for a high quality unit like the Corsair. Just my thoughts.
Sniper
More Information
Dagger, CoolerMaster PSUs are considered Tire 4/5 (except the higher end ones ie 700W which are ~Tire 3).
See:
http://www.xtremesystems.org/forum [...] p?t=108088
Remember Watts do not equal quality.
Message quoted 1 times
Message edited by Shadow7037 93 on 05-12-2008 at 12:44:45 AM
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
Sniper
More Information
Agreed!
More Information
See:
Lol, nice chart. It's a wonder manufacturers didn't sue those guys for defamation, considering how they list brands like that. :sol:
But yeah, I have no idea what brand is good or not. Listen to people who do.
Looking at that, mine is on low tier 4, but all rails output is rock solid on stress. Plus, it haven't got a single bad buyer review on Newegg, only 4 and 5s on a scale of 1-5. I wanted to buy brand name first, but saw the price, and then the good reviews, and considering newegg's return policy, decided to go for the bargain instead.
How scientific is that chart? How big a cross sample for each model of each brand do they test? It should be at least 500+ per model to be statistically significant.
Btw, just noticed something. On the psu, it says "Zumax" with "epower" only in the fine print. Maybe they saw the chart and tried to ditch the bum rep? :na:
More Information
If Ultra's guys saw that chart they'd sue alright...
They sue everybody. Then they take 350W hardware, put a 600W sticker on it and sell it for $100+.
You can't go wrong with that chart IMO. An Enermax Galaxy dies from time to time. But 10 minutes before it dies it still offers 99.9% accurate voltages.
And it doesn't take a $350 motherboard with it when it goes. :D
More Information
:pfff:
For the most part the brands are listed in alphabetical order within each tier. The order within the tier has no significance. I noticed that you didn't list the Brand of PSU in your sig, are you embarrassed? Maybe you should be looking at a new PSU as well. I guess that's like the blind leading the blind.
Don't you think that expecting testing on 500+ PSUs of each type is ludicrous. They test and or dissect the PSUs to determine what components e.g., capacitors etc. are used and the design of the PSU itself. I'm sure they get their data elsewhere as well. The list should be used as a guide. If your PSU is a tier 4 or 5 it is probably junk.
Message edited by Zorg on 05-12-2008 at 01:33:25 AM
More Information
Actually, the current psu is a replacement for this one, which keeps crashing my new rig.
http://www.newegg.com/Product/Prod [...] 6817194004
After monitoring output, it's clear. Output voltage fluctuates far too much. No wonder. I purchased this after some guy online recommended this exact model. Ignored some of the... rather humbling reviews it got on newegg because I thought they were just noobs whinning. After getting burned on that, I returned it, got the first bargain listed, and was pleasantly surprised with the rock stable output even on high stress.
Looking at the chart, it's on tier 2. :sarcastic:
Not saying it's bad. Surely I just got a bad apple. You really should read the user reviews though. Hey, at least the bad apple I got didn't explode like that poor sob who wrote one of the reviews. :p
More Information
Never had the chance to handle a Liberty(I guess I should be happy about that). INFINITIs are quite good
http://www.newegg.com/Product/Prod [...] 6817194021
Installed two with no issues. I had a Galaxy 850W die on me about one hour into my friend's build (15 minutes after installing Windows (we checked the voltages a few minutes before that and they didn't move at all). 2 reboots later it just dies. No smoke. No fire. Nothing. The replacement unit still works 1 year later and powers a nice little WS with 8HDDs.
Message edited by Andrius on 05-12-2008 at 02:57:46 AM
More Information
Just because the PSU is well respected doesn't mean there will be zero failures. Dagger, just out of curiosity what is the model of your PSU?
It appears that Newegg is having a hell of a sale on PSUs. 750TX, Silencer 750 and the Enermax.
Message edited by Zorg on 05-12-2008 at 03:12:37 AM
More Information
I built the rig only one month ago. Both models are linked in eariler posts. And yeah, anything can be defective. It's a matter of luck. :p
More Information
^dagger's rig plumbing : http://www.newegg.com/Product/Prod [...] 6817101029
I don't know if it's the pictures on newegg but it looks like it's been put together with caveman tools. Look at the gaps in the metal casing!
Those cables look like you could kill someone with them. The rear voltage switch is so 1995 ;)... what's it for ?
Message edited by Andrius on 05-12-2008 at 03:55:56 AM
More Information
Those cables look like you could kill someone with them. The rear voltage switch is so 1995  ;) ... what's it for ?
That gap is the width of the cross bars that held the fan guard in place. It can't be helped. That voltage switch is so it can be used in Europe... and Asia... and everywhere else other than US. :p
More Information
That's a Topower unit. I couldn't find any reviews on it. I noticed what I assume is yours that said
Quote :
...recommended models from what they considered "good" brands, which cost around $200 for a 500 watt model with around 40amps total on 12v rails. review on Newegg that stated
That doesn't make sense because the Silencer 610 has been only $119 for at least a few months.
Since you are not loading the ePower very heavily, maybe it will work out good for you, I hope so.
