Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > First DYI build in over 2 years, any thoughts?
Forum Homebuilt Systems : General Homebuilt - First DYI build in over 2 years, any thoughts?
Here is the build, trying to keep it under 1000.00.
Cooler Master RC-690
http://www.newegg.com/Product/Prod [...] 6811119137
Gigabyte GA-P35
http://www.newegg.com/Product/Prod [...] 6813128059
Intel Core2 Duo
http://www.newegg.com/Product/Prod [...] 6819115028
4gb G-Skill DDR2 1066
http://www.newegg.com/Product/Prod [...] 6820231166
EVGA 8800gt
http://www.newegg.com/Product/Prod [...] 6814130318
250GB Seagate HD
http://www.newegg.com/Product/Prod [...] 6822148262
This also includes Vista Ultimate 64bit with SP1. Final tally is roughly 940.00
This will be primarily a gaming machine. How does it look? I didn't list and dvd/cd combo drive as I can pick it up later. Am I ready to hit the buy button? Should I get some more case fans since the RC-690 has alot of space for them? Also, is it crucial that I by Arctic silver? I never done it before and I am a bit nervous about using it.
Message edited by arson on 05-11-2008 at 11:54:09 PM
Sponsored Links
You selected good components, so here's some thoughts :
CPU : consider this 45nm : http://www.newegg.com/Product/Prod [...] 6819115037 (new 45nm, runs cooler, overclocks better).
For basic cooling any thermal paste will do (most coolers come with a batch or some paste preapplied) so you don't have to buy Arctic Silver but make sure you use some paste when you build. On that note what CPU cooler will you be using. The stock one is rubish. Consider the XIGMATEK HDT-1283 for ~$40 on newegg.
http://www.newegg.com/Product/Prod [...] bhdt-s1283
The 250GB drive is good and cheap but it's from the previous generation.
Make sure you pick one of the 7200.11 series like this http://www.newegg.com/Product/Prod [...] 6822148316
If you want a bit more space and performance go for WD6400AAKS (good value at $115 on newegg and has excellent performance - research it if you want).
Make sure your DVDRW drive is SATA (if you decide to buy one).
CASE : No need to buy extra case fans. See how this performs and decide if you need more. Your selection is pretty standard and won't run too hot.
Graphics : You might also check out an 8800 GTS (around ~$225). It has a bit better performance and better cooling than the 8800GT.
PSU : make sure you have a 450W or more quality unit. If not check out the Corsair VX 550W at www.buy.com for $70.
Good luck
Message edited by Andrius on 05-12-2008 at 01:01:35 AM
Reply to Andrius
- 0 +
I agree with Andrius on all points.
The GA-P35-DS3L is a good motherboard, but it has an awful lot of limitations. The part about only 4 SATA ports is the most painful, IMO.
$50 more buys you something much nicer:
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813127030
Reply to aevm
- 0 +
I just noticed I forgot to comment the RAM.
If you won't overclock beyond say 450MHz FSB (that would put you beyond 4GHz) the RAM you're getting is overpriced. This is close for overclocking ability but costs $60 less:
http://www.newegg.com/Product/Prod [...] 6820231145
You can also pick a cheaper 800MHz DDR2 kit and overclock it a bit.
My Geil modules run stable at 4-4-4-12 upto 848MHz on my quadcore.
Message edited by Andrius on 05-12-2008 at 02:22:22 AM
Reply to Andrius
- 0 +
Thanks alot guys. I actually cancelled my order after reading the responses. I re-ordered and changed out the ram, HD, cpu, and gfx from everyone's suggestions. Actually saved some money and got a better machine. I am thinking about getting that heatsink that was mentioned. I only hope it will fit in my case.
If I get it, will you guys give me some pointers on how to overclock it? Back in the day, I would just up the speed in the bios and wouldnt care if I messed things up, but now I want to do things right. Or perhaps there is a guide to overclocking here on toms articles. I also decided to keep that gigabyte mobo.
Thanks!
Message edited by arson on 05-12-2008 at 04:33:52 AM
Reply to arson
That looks like a great mid-range system. I only hope you went with a 45nm cpu, they run much cooler and are more efficient.
Make sure and tell us what you got. :)
Reply to theTHiiiNG
- 0 +
Will do! I did not realize after canceling my first order that it would take 3-5 days for my newegg preferred account to clear the old charge before I can place another order! Looks like I will be placing this order this weekend/early next week. But I think its worth it. I was stoked about having it this week due to my wife being out of town. Oh well
Message edited by arson on 05-12-2008 at 10:13:57 PM
Reply to arson
There are 1408 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
