Tom's Hardware > Forum > CPU & Components > Other Components > help in building new gaming pc
ok..so i building a new gaming pc.... but im kind of a beginner in this...
so any kind of help will be good...
my components that i have decided to buy:
Western Digital Caviar 400GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM 70$
http://www.newegg.com/Product/Prod [...] 6822136076
Intel Core 2 Quad Q9300 275$
http://www.newegg.com/Product/Prod [...] 6819115043
ZEROtherm CPU Cooler 40$
http://www.tigerdirect.com/applica [...] CatId=1588
SilverStone / ST85ZF / 850-Watt
http://www.tigerdirect.com/applica [...] CatId=2036
if you have any other suggestions... please.. :D
the components that im not sure which with what... :
EVGA nForce 790i Ultra SLI Motherboard ( does it support 3-SLI PCI-e 2.0 or just 2 PCI-e 2.0 with another PCI-e)??
http://www.tigerdirect.com/applica [...] CatId=2014
with
Corsair XMS3 DHX 2048MB Dual Channel PC10600 DDR3 1333MHz Memory (2 x1024MB)
http://www.tigerdirect.com/applica [...] CatId=3433
or
EVGA nforce 780i SLI Motherboard
http://www.tigerdirect.com/applica [...] etailspecs
with
Corsair Dual Channel 4096MB PC6400 DDR2 800MHz Memory
http://www.tigerdirect.com/applica [...] CatId=3412
any ideas are good :D
and...the most important thing... the Graphic card
i cant decide between :
2x EVGA GeForce 9800 GTX in SLI
http://www.tigerdirect.com/applica [...] CatId=3670
or
2x EVGA GeForce 8800 GTS in SLI
http://www.tigerdirect.com/applica [...] No=3728403
helpppp :cry: :cry:
and 850 watt will do good with all this ??
Sponsored Links
hmm... what does it mean power index = 17 ?
and i was considering on going with the asus rampage formula with intel x48 chipset.... but its to old and costs like the 790i ultra... right ?
Reply to uhxto
X48 isn't old, it just came out this year. Nvidia chipsets have trouble overclocking not as well compared to Intel chipsets. If you have the cash, I would go for the Q9450 instead of the Q9300 as the Q9300 is handicap with 6 mb of L2 cache instead of 12 in the Q9450. I have the rampage with the Q9450 and it can be overclocked with ease to 3.6ghz.
Reply to Shadowthor
- 0 +
well... i think i will wait another week to see the new graphic cards
...but if i get the rampage formula i will have to use the crossfireX....
can u suggest for me a good gaming motherboard with intel chipset x48 that supports SLI and not crossfireX
Reply to uhxto
- 0 +
aha...so you do recommend the rampage formula ?
Reply to uhxto
WTF? Those numbers are for telling what Gen. and what performance class.
Message edited by pcgamer12 on 06-15-2008 at 10:00:13 PM
Reply to pcgamer12
- -1 +
his index is bull, but his recommendations are good.
Reply to pcgamer12
- 0 +
thank you all guys...
what about Intel DX48BT2 ?
http://www.tigerdirect.com/applica [...] CatId=3646
is this board is good ?
Message edited by uhxto on 06-15-2008 at 11:03:15 PM
Reply to uhxto
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
