Tom's Hardware Forums » CPU & Components » CPUs » Q6600 Overheating @ Stock Speed w/AS5 & Freezer Pro7 -Help me fix !
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Q6600 Overheating @ Stock Speed w/AS5 & Freezer Pro7 -Help me fix !
Profile: stranger
More Information
My System Config:
I have assembled my PC with Q6600 (at stock speed) and GA-EP35C-DS3R board.
Artic Freezer Pro 7 HSU and Arctic Silver 5 compound.
Antec Sonata III 500 Case.
Issue:
Recently I have noticed (via speedfan) that my CPU is running very hot. The CPU core is running between 55C-59C idle while the system temperature is around 44C. I had setup bios to shut down CPU if it goes above 60C. Ambient temperature is around 22-25C.
Is this normal for CPU cores to run at 59C?
How can I cool the system in order to Overclock in future?
Your advice is very appreciated.
=ShyGuyCalif
Message quoted 1 times
Message edited by shyguycali f on 06-16-2008 at 05:10:17 PM
Related Pr oduct
Tarheel Blue thru and thru!
Profile: addict
More Information
First of all, did you calibrate SpeedFan? If you didn't then you can't necessarily trust that reading. Download RealTemp, or CoreTemp (or both to be sure) and compare the readings.
You can't always trust these thermal monitoring apps right out of the box.
Xeon X3350@3.4GHz w/TRUE 120 - Asus Maximus Formula SE
4x1GB Corsair Dominator DDR2-1066 - EVGA 8800 GT @ 675 Core
2x 36G WD Raptor 10k RPM
Antec 900 w/PC Power & Cooling Silencer 610w
Profile: Ancient Poster
More Information
first the temps are normal - thats not over heating
second that cooler sucks
third turn it up to 3.6ghz and keep it below 70c and you be happy!
after you sell that hsf on ebay read this:
http://www.tomshardware.com/forum/ [...] tic-forgot
but one of those
Message edited by dragonspra yer on 06-16-2008 at 11:09:55 PM
http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Profile: enthusiast
More Information
http://www.techpowerup.com/downloa [...] Real_Temp/ download ver 2.6 and run it, then post your temps.
Never under estimate peoples capacity for stupidity, and you won't be disappointed.
kad
Profile: addict
More Information
shyguycalif wrote :
[#0000ff][u][b]
I think you havr high temps
With ambient 25 and OC to 3-3.2 GHZ you should idle at 45 and under Prime95 willbe 55-60
USE RealTemp2.5 to check your temps and forget everything else
Do not use CoreTemp
1-Run first your system with case open and see if temps are better maybe you need to improve airflow
2-Get TRUE heat sink and the Sythe fan mentioned in my sig
3- Get OCZ Freeze Extreme Thermal paste
LianLi PC-A70 Case/Enermaqx Galaxy 1000W/Asus Rampage Formula/E8500/Thermalright Ultra 120 Extreme Lapped/Scythe S-Flex SFF21F/Crucial Ballistic Red Line DDR2800 PC6400(2X2)GB/8800GTS 512MB/WD Raptor2X150GB/ViewSonic VX922(1280X1024Max)
Add a reply
Google Ads
