Need a new motherboard probably X48 for 2 HD4850 in cf. I would like to use DD2 800 memory since I already 4 gigs from my existing build. My budget is under $300 if possible and with good overclocking. DO I Need to reformat my harddrives since I'm still using the same LGA775 chip set? My other requirement would have to have a 3rd PCIE connections for 3 cards. ( I Know I will need a new power supply but this is for later on). Any help would be appricated..
975XBX board
Q6600
Zalaman cnp9500
4 gigs DDR2 800
2 74 gig raptors in raid HD4850 in C/F
Corsairs hx620 power supply
audigy 2zs
dvd buner
cd burner
floppy drive
250 gig external drive
When asking questions like this you really should state your geographic location, that can affect the recommendation of source. WRT the need to reformat and reinstall, no, you can run sysprep immediately prior to doing the changeover, shut down, swap boards, and reinstall your new mobo drivers. sysprep removes the mobo/chipset specific drivers turning your install into a generic one where you will have to install the chipset drivers for the new board. Google for further information. Note: sysprep works for W2k and XP.
Message edited by rgsaunders on 07-11-2008 at 12:56:14 AM
------------------------------Never under estimate peoples capacity for stupidity, and you won't be disappointed.
Reply to rgsaunders
Hey thanks for the quick response. I live here in the US (CA) and us pc for games like counter strike, Crysis, COD4, Supreme commander, and WIC also SC2 whenever that comes out. Plus I do some video editing and work stuff. Between ASUS and GIGABTE which one is the best? I will be overclocking.
Hey Guys sorry but found a couple that fit my budget which is the best? How's DFI? They have one that has 3 PCIE slots. I don't about audio that comes with either one.
I've been using a Rampage for the past few months and am very happy with it. DFI boards are good, but you really have to know what you're doing to get them set up correctly. Foxcon is supposed to have a X48 board that's fairly good as well. But like I say, I'm very happy with my Rampage.
------------------------------Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
Over 50. Seen it, done it, can't remember it, but I miss it.
Reply to Sailer
