Tom's Hardware Forums » CPU & Components » CPUs » Quad Dual and cpu speed
Word :   Username :
Bottom
Author
 Thread : Quad Dual and cpu speed
Profile: journeyman
More Information
So I was browsing trademe (nz ebay website) anyways this guy listed a q6600 as 9.6ghz, 2.4GHzx4. I was always under the assumption that you don't multiply the cores they simply help for multi tasking and what not.
Related Product
Nuke it, Nuke it good!
Profile: Eternal Poster
More Information
your right(the cpus work in parallel), the ebay seller either does not understand or wants to scam people. Lots of users just don't know and like the sound of 9.6.
An application that only uses one core will run the same speed on that as a single core, But with more cores, more apps run more smoothly together. and some apps(audio video and some games) can use more cores together for a boost
Message edited by nukemaster on 06-16-2008 at 08:38:33 PM
http://img145.imageshack.us/img145/4269/inukexz9.png
http://tinyurl.com/26uxxb - Core2 Temp Guide? http://tinyurl.com/cj3pw - VGA power use?
http://tinyurl.com/5v55wk - Core2 Memory performance? http://tinyurl.com/6pmbke - SLI/Xfire?
Do not eat the styrofoam
Profile: Forum Fixture
More Information
Or maybe the seller is just trying to dumb it down so he can reach more potential customers. Some people will think E6600 and Q6600 are the same since they're both running at 2.4 GHz. It's mostly Intel's fault, after years of brainwashing ads that stressed the higher clocks.
Here's an example:
You're encoding a video, and your hard disk is VERY fast, and your software works on all 4 cores. Then yes, the job is done on a Q6600 at 2.4 GHz about twice as fast as on an E6600 (2 cores) at 2.4 GHz. You can think of the Q6600 as an E6600 at 4.8 GHz. If there was a single-core CPU in this family, yeah, it would need to run at 9.6 GHz to finish that job in the same time.
The sad truth is, in most programs, including most games, cores 3 and 4 will be idle, and even then the hard disk or video card will be a bottleneck preventing cores 1 and 2 from running at 100%.
Profile: addict
More Information
the guy doesn't know wha he's talking about. hopefully he's charhing $200x1 and not $200x4 lol.
Phenom 9500 @2.5ghz|MSI K9A2 Platinum|500Gb,750Gb Seagate 7200.11|2Gb OCZ Ram|Diamond HD3870 @850Mhz|CM 690|OCZ 700Watt
More Information
Here's an example:
Thats why you game and encode :)
Profile: Ancient Poster
More Information
well - yes thats true
i will admitt - i fought people over that since its wrong and finally i did the same thing to show them it was wrong
its wrong - kinda of
if all 4 cores are working together why is it not the same?
no 3.6x4 cores does not equal a 15ghz machine but it can be about the same under many circumstanous and a good way to rate systems
E8400 at 4.25= 8.5 equivelent rating
while a Q6600 at 3.6 = 14.4E
it does give a good feel for multitasking
then a tri core at 2.5ghz = 7.5E
now if you take in consider the number of calcs per cycle you have a good rating system.
a p4 does 2 while amd and c2d do 3
so a p4 (old p4 the name is resused and its a c2d for the most part) such as a dual core 3ghz at 4ghz would be an 8 x 2/3 = 5.5E
so i would take the E8400 at oc over an amd tri core
Message edited by dragonsprayer on 06-19-2008 at 06:11:15 AM
http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Google Ads
News
Quad-core Clovertown server CPU to launch on 16 November
Published on September 26, 2006
Intel will announce two-way quad-core server Clovertown processors, which will be marketed under the Xeon 5300-series name, on 16 November, according to Taiwan-based motherboard makers. Read more
Kentsfield quad-core processors to sell for less than $1200
Published on November 10, 2006
While Intel reportedly is gearing for a launch of its quad-core processors on Monday next week, a wide range of etailers has begun pre-selling or even selling the Core 2 Extreme QX6700 processor. Read more
Intel To Update Desktop CPU Lines In Q3
Published on May 20, 2008
More here at Read more
Intel quad-core Kentsfield to be named Core 2 Quadro
Published on September 19, 2006
Intel is expected by the end of this month to officially name its Kentsfield quad-core desktop processor as the "Core 2 Quadro," with the first model to be an Extreme version, the Core 2 Extreme QX6700, which will be available starting in mid-November, according to sources at leading Taiwan motherboard makers. Read more
Latest Reviews & Articles
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
