unsure about power supply
nannerla
101
I am building a new computer mostly from scratch but I have the 2 harddrives and an evga 8800gts 320mb i plan on using for now but am unsure if my current 500w Antec Smartpower 2.0 will be enough to power my new setup, heres the rest of the parts.
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-05 - OEM x2
SAMSUNG Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
OCZ Gold 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
EVGA 122-CK-NF66-T1 LGA 775 NVIDIA nForce 650i Ultra
Intel Core 2 Duo E8400 Wolfdale That i plan on ocing to 4ghz or so
case is an antec 900 with 1 200mm fan and 4 120 mm fans.
Also does anyone have any other suggestions for the motherboard?
dagger
Splendid
Mar 23, 2008
5,624
500watt psu with good 12v rail ampage should be enough. Get x38/48 or p45 for max oc on e8400, which is good for 4.3ghz. Anything else at the moment will bottleneck the e8400.
dagger
Splendid
Mar 23, 2008
5,624
invisik
2,476
ull be fine considering my antec 500 earthwatt is powering a qq6600 oc @3.0
9800gx2 oc @ 722/1126, 4gig of ram. 2 hardrive, blue ray player.
