Ok so i restarted my pc, then all of a sudden. I get no display.. my monitor is black... and my computer case started making this horrible huuuge fan noise... It came from my Geforce 7600GT... as i looked closer the fan was moving at a snail speed pace... but making this huuuge noise.. and i recieve no display on the monitor... What can i do?? HELP!!! Was working perfectly earlier i was playin Counter-Strike Source...
I put the sound card in, installed drivers sound didnt work. Restarted. No work, turned off pc. TInkered with it. TO see if it was seated correctly turned on again. Turn off again tried again. Then it gave me problems.. I dont have a extra Card to put into the pci-express slot
Seems to me the gaming god saying you need a new card. XD
I had a similar problem with my 7600gt sli setup (I know!). I was playing BF2 and suddenly the monitor went black. I figured one of the cards were messed up. I took out the top video card and tested the bottom sli card if my computer was still working and it is. Tested the 1st vc and BAM! cheezit, it wasnt working. so i pretty much RMAed the poor thing. Didnt really bother looking what the problem is, since it was still under warranty
