Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Is this Power Supply enough for 8800 GT
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Is this Power Supply enough for 8800 GT
Profile: stranger
More Information
Currently running
Quad Core 6600
3 GB Ram
2 - 250 GB HD's
Radeon 2400
LG 22" LCD
and the system has a 300 W Power Supply
I want to upgrade to an 8800 GT Vid Card
This one in particular: http://www.tigerdirect.ca/applicat [...] u=B52-8808
it says:
"Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 22 Amp Amps.)"
I have a power supply that my friend just gave me it is an ATX 400W p4 PSU
under that it says the following numbers:
+5V -5V +12V -12V +3.3V +5VSB
30A 0.5A 15A 0.8A 20A 2A
My question in regards to this PSU - would this be enough to run an 8800 GT 512mb card? There is a little sticker on the top... it appears to have been manufactured in 2005 - would that have any bearing on its usefulness (for example correct connectors?).
Basically I'm trying to avoid buying a new PSU if possible.
Thanks
Related Pr oduct
Profile: Eternal Poster
More Information
It's not enough. There's q6600, which is a power hog, to add in too.
Q6600@3.6ghz, GA-EX38-DS4 X38 chipset motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB 7200rpm 32mb cache hdd, 850watt 12v rails=4x20amp powersupply
Profile: stranger
More Information
Thanks.
Could you point me to some PSU's that would be sufficient to run an 8800 GT?
Preferably price friendly.
More Information
bbgman wrote :
Thanks.
Q6600 plus 8800gt should need at least 450watt with decent 12v rail ratings. Ideally, go above that just to be safe and allow room for upgrade.
Gamer and Hardware Addict
Profile: member
More Information
Christopherr wrote :
8800gt = 8+8+0+0 =16. + almost a half of it;s power idnex for free space. Energy should be palced somewhere too.
wtf?
Message edited by liljone on 06-19-2008 at 06:03:43 AM
Processor: Intel Core2 Duo CPU E6700 4MB L2 Cache @ 2.67Ghz.
Memory: 4GB (PC2 6400)
Video Card: NVIDIA GeForce 7950 GT OC 512mb (565MHz/1430MHz)
Audio: SB X-Fi Xtreme Audio
Add a reply
Google Ads
