Here's the computer http://www.newegg.com/Product/Product.aspx?Item=N82E16883113088 I recently took it apart and put it back together. I got everything connected properly except for the power switch, I don't have a booklet for the amd 780g motherboard, and the diagram I found online doesn't match mine so I just plugged it into the red slot on the front panel connector. The computer boots up into power saving mode (The power button LED pulses like it's in sleep mode and when I turn the LG monitor on it shows the LG logo then it says that it's entering power saving mode and goes black) I checked all the cables and everything is plugged in, I don't know what the problem could be.
